hi tomcon,
www.fugawi.de =>
Frage: Auf meiner Top50 CD befinden sich Höhendaten, diese lassen sich aber nicht in Fugawi importieren. Was mache ich falsch?
Antwort:
Sie machen gar nichts falsch. Diese Daten lassen sich momentan noch nicht in Fugawi importieren. Wir bieten Ihnen aber ein lückenloses Welthöhenmodell, von dem Sie die Höhendaten in Fugawi importieren können
in deiner soft gehe auf HILFE ; Höhendaten finden...
dann kommt this:
Worldwide NIMA DTED® Digital Terrain Elevation Data
The US Department of Defense offers world-wide elevation data in DTED format. The data is available in different resolutions, with Level 0 being the lowest level of resolution. Level 0 data is spaced at 30 seconds of latitude and longitude (about 900 meters, depending on latitude). The Level 0 data is available over the internet for civilians as follows:
Go to
http://geoengine.nima.mil
Click on the map to zoom in to a reasonable-sized area (for example the size of Germany).
Click on the Download/Order tab.
In the DTED section click on Download.
Click on Build File for Download
When the sceen says "Download Your Zip File" and "Your File is Ready", click on the file name to download.
Unzip the zip file (see
www.winzip.com for a program to unzip the file). Place the unzipped files in a new folder with a name that will help you identify the region. Be sure there is no dmed. file, text folder, or dted folder already in this destination folder. If any of these files/folders exist in the destination folder, they will be overwritten and your DTED® software tools may not perform properly. Do not alter the folder structure once the data have been unzipped.
In Fugawi go to Forms|Elevation Library
Set the type of file to DTED.
Click on the "+" button to add the new data to your elevation library.
fettisch is die höhe,
allerdings muss man schon etwas probieren bis es klappt,
aber du schaffst das
gruß
gandhi
