Hi!
Ich stehe mittlerweile nach langem hin und her schauen, vor der Kaufentscheidung der zwei folgenden Bikes:
Cube AMS PRO:
http://www.cubebikes.de/cube_bikes/kit/kit_ams_pro.pdf
mit Kit8
Specialized Epic Comp:
FRAME All new 06 Epic, FSR technology, optimized for Brain Fade shock, M5 alloy fully manipulated frame with ORE DT/TT, sealed cartridge bearings, disc only, 100mm travel, replaceable derailer hanger
REAR SHOCK Specialized Fox Brain Fade shock, adjustable from hardtail firm to trail tune, air spring, rebound adjustment, 11.7"X1.87"
FORK Fox F100 RL, air spring, rebound/compression adjustment with lock out, 100mm travel, alloy steerer
HEADSET 1 1/8" threadless, 10mm insertion alloy cups, sealed cartridge bearing
STEM 3D forged CNC machined, 4-bolt face plate, 31.8mm OS clamp, 8 degree rise
HANDLEBARS Specialized 2014 butted alloy flat bar, 600mm width, 31.8mm
GRIPS Specialized MTB grip, black/charcoal
FRONT BRAKE
Shimano M-765, hydraulic caliper, 6" rotor, metallic pads
REAR BRAKE
BRAKE LEVERS
Shimano XT
FRONT DERAILLEUR
Shimano M-580 LX, 34.9mm clamp, bottom swing, dual pull
REAR DERAILLEUR
Shimano M-952 XTR, long cage, standard spring
SHIFT LEVERS
Shimano M-570 LX
CASSETTE
Shimano HG-50, 9-speed, 11-34t
CHAIN
SRAM PC-971 with Power Link
CRANKSET
Shimano M-760 XT Hollowtech II, 2-piece crank/BB
CHAINRINGS 22A/32/44 4mm thick outer, 4-bolt 104/64mm, alloy chainring bolts
BOTTOM BRACKET
Shimano M-760 XT, Integrated with crank
PEDALS
Shimano M-520 SPD
RIMS
Mavic XM317 Disc 26", black, eyelets
FRONT HUB Specialized Stout disc, sealed cartridge bearing, high/low flange, 32 hole
REAR HUB
Shimano M-525, 32 hole, alloy QR
SPOKES
DT Swiss 1.8mm, black, alloy nipples
FRONT TIRE Specialized Fast Trak Pro 26x2.0", aramid bead, dual compound
REAR TIRE Specialized Fast Trak Pro 26x2.0", aramid bead, dual compound
TUBES Specialized Ultralight, presta valve
SADDLE Specialized Body Geometry Rival, hollow Cr-Mo rails
SEAT POST 2014 butted alloy, black, 30.9x350/400mm
SEAT BINDER 7050 hard annodized alloy collar with QR, 34.9mm clamp ID, black
NOTES Chain stay/seat stay protector, reflectors, owners manual
Welches Rad würdet ihr mir empfehlen?
Danke für eure Hilfe,
mfg
offline4u
