Neues 221 TI Full disc monty und erklärung von canas und comas, warum disc hinten beser ist. (habe punkt 5 nicht kapiert...
New 221 TI Full Disc 2006 25/07/2005
Already is for sale the new Monty´s machine, the legendary 221 TI Full Disc, now with rear disc brake and new design improved, that becomes the best BikeTrial bicycle of every time. It thought and built to gain. Try it now! It is presented in finished tricolor: red, black, white, and in the already classical one scrothchbrite
2006 IMPROVEMENTS
- Frame: Upgrated frame design
- New rear drop disc
- Rear brake:
Magura Marta SL Dia.160mm
- Brake pads: New design & composite
- Fork: New disc drop
- Tires: New biketrial composite
New rear size 19x2.6
- Decals: Water type decals
Cesar Cañas and Dani Comas explained to us the 10 improvements that suppose the disc brake, compared with the hydraulic, before and behind.
1- Equal weight than the hydraulic rim brake system .
2- No longer does that noise that we used to, but that it turn ed out to be unpleasant and uncomfortable.
3- No necessary to scratch the rims in case of raining or to put tar on them in case of dry ground. . Only should you catch the bike and train!
4- We have not to deflate the wheel to change a camera or etc ..
5- The main characteristic that they tell us is : with the hydraulic brake system , when you jumped to the climb of a rock and if you did not arrive, the wheel rotated and remained far away and no longer recovered the right position, with the rear disc brake system if you do not arrive, you can recover the right position just at the
edge of the rock . This point is very important .
6- No more brake shoes movement.
7- You can descend a slope without having to get out of the bike.
8- With the hydraulic rim brakes, when one had to tauten the brakes, at times , the rim approached more to one side of the bombin, right or left . Always a big annoyance
9- With the hydraulic brake system , if the rim received a blow , automatically, the breaking performance changed . It is evident that it does not happen with the disc brake system .
10- The disc brake performance is very progressive and precise compared to the hydraulic brake one which is irregular and too abrupt.
They also told us that once you test the disc brake system no longer you want to return to the hydraulic brakes.
SPECIFICATIONS
-Frame: Monty 7005-T6. Tri-butted. Tig Plus. Shock absorbing. Concave design.
-Fork: Monty 6061-T6. Disc drop. Cr.Moly hollowed sleeve. Blade gussets.
-Head set: FSA. Semi-integrated. 7075 alloy cups. Seal contact bearings.
-Stem: Monty 6061-T6. L150mm. 26/ degree, Bar bore 31.8mm. Carbon fiber
-Handlebar: Monty 7075-T6. Tri-butted. L680mm. O.D.31.8mm. 10/back. 11/up
-Brakes:
Magura Marta SL (F & R). Hydraulic system. Dia 160mm. Dual piston.
-BB Parts: FSA. ISIS type. Oversize Cr.Moly spindle. Aluminium cups. L124mm
-Cranks: Monty 7075-T6. ISIS type. Cold forged. L158mm. 1.37x24T thread.
-Freewheel:
Shimano 18T. C.P. finish.
-Skiplate: Monty 6061. Eagle Claw patent pending.
-Rims: Monty 6061-T5. Front 20-32H. Rear 19-36H. Double wall. Titanium.
-Tires: Monty special BikeTrial composite. Front 20x2.0. Rear 20x2.6.
