- 3. Juni 2013
- 2
Gewicht Rahmengrösse L 12.2kg
Frame
Scale Alloy 6061
custom butted superlight tubing
Tapered HT / BB 92
bridgeless seatstays
Integ. Headset / replaceable hanger
Fork
Fox 32 Float Evolution CTD Air
CTD damper with 3 modes
15mm QR axle / tapered steerer
reb. Adj. / 100mm travel
Remote System
Scott Rideloc Remote Technology
3 modes
Headset
Ritchey Comp Plus Tapered 1.5" - 1 1/8"
semi integr. OD 50/61mm / ID 44/55mm
Derailleur (Rear)
Shimano XT RD-M781 SGS
Shadow Type / 30 Speed
Derailleur (Front)
Shimano SLX FD-M670 / 34.9mm
Shifters
Shimano SLX SL-M670
Rapidfire plus / 2 way release
Ispec clamp
Brake Levers
Shimano BL-M596 Disc
Brakes
Shimano BR-M596 Disc
180/F and 160/R mm SM-RT64 CL Rotor
Crankset
Shimano XT FC-M780
hollowtech 2
42Ax32Ax24A T
BB-Set
Shimano SM-BB71-41A / shell 41x89.5mm
Handlebar
Syncros FL2.0 Tbar
6061 D.B. / OS / 700mm
H'stem
Syncros FL1.5
7050 Alloy / oversize 31.8mm
1-1/8" / 6° angle
Seatpost
Syncros FL2.5 / 31.6mm
Seat
Syncros XR2.0 / CROM rails
Hub (Front)
Formula CL81 / 15mm
Hub (Rear)
Shimano FH-M629 Disc CL
Chain
Shimano CN-HG54
Cassette
Shimano SLX CS-HG81-10
11-36 T
Spokes
DT Swiss Champion Black 1.8mm
Rims
Syncros XC 37 / Eyelets / 32H
Tires
Schwalbe Rocket Ron EVO / 2.1
127EPI Kevlar Bead
Pace star compound
Ritchey Pro V3 MTN Pedale
Wo würdet ihr Potential sehen das Radl möglichst ökonomisch in den Bereich von 10 kg zu bringen?
Grüsse
Chris
Frame
Scale Alloy 6061
Tapered HT / BB 92
Fork
Remote System
3 modes
Headset
Derailleur (Rear)
Derailleur (Front)
Shifters
Shimano SLX SL-M670
Ispec clamp
Brake Levers
Brakes
Crankset
Shimano XT FC-M780
hollowtech 2
42Ax32Ax24A T
BB-Set
Handlebar
Syncros FL2.0 Tbar
H'stem
Syncros FL1.5
1-1/8" / 6° angle
Seatpost
Seat
Hub (Front)
Formula CL81 / 15mm
Hub (Rear)
Chain
Shimano CN-HG54
Cassette
11-36 T
Spokes
Rims
Tires
127EPI Kevlar Bead
Pace star compound
Grüsse
Chris
