brauche Entscheidungshilfe
zur Auswahl stehen ein
Camber Comp 29 2012 für ca. 1850 Euro (Vorführrad)
oder ein
Camber Comp 29 2013 für ca. 2100 Euro.
Was denkt ihr? lohnt sich der Aufpreis?
Ich weiß das das 2013er eine neue Anlenkung hat. Weniger Drehpunte = steifer.
Hier die Ausstattung 2012:
FRAME
M5 hydroformed tubing, 29" geometry, tapered HT, PF30 BB, Command Post routing, 142mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, bolt-on cable guides, 110mm travel
REAR SHOCK
Custom Fox Triad II, custom for 29er on-the-fly 3-position compression switch 1) Lock out 2) Open 3) ProPedal, rebound adj., 200x49mm
FORK
Fox Float Evolution RL 29, open bath damper, tapered steerer, LO and reb adj., standard drop-outs, 110mm travel
HEADSET
1-1/8 and 1-1/2" Threadless, Campy style upper with 1-1/2" lower, cartridge bearings
STEM
Specialized XC, 3D forged alloy, 4-bolt, 31.8mm clamp, adjustable rise, S: 60mm, M: 75, L:90, XL/XXL:105mm
HANDLEBARS
Specialized XC Mini-Riser, 7050 butted alloy, 720mm wide, 10mm rise, 10º backsweep, 6º upsweep, 31.8mm
GRIPS
Specialized lock-on, S/M: Grappler, Others: Grappler XL
FRONT BRAKE
Custom
Avid Elixir 7 SL, hydraulic disc, alloy backed semi-metallic pad, HS-1 rotor S/M:180mm, Others: 200mm
REAR BRAKE
Custom
Avid Elixir 7 SL, hydraulic disc, alloy backed semi-metallic pad, HS-1 rotor S/M:160mm, Others: 180mm
BRAKE LEVERS
Custom
Avid Elixir 7 SL hydraulic, tool-less reach adj.
FRONT DERAILLEUR
SRAM X7, 10-speed, S3 direct mount for DMD, top-pull
REAR DERAILLEUR
Shimano XT Shadow M780, 10-speed, GS medium cage
SHIFT LEVERS
Shimano SLX M660, 10-speed, trigger
CASSETTE
SRAM PG-1030, 10-speed, 11-36t
CHAIN
KMC X-10, 10-speed, w/ reusable Missing Link, nickel plates
CRANKSET
Custom
SRAM S-1250, 10-speed XC Trail double, PF30 spindle, S: 170mm, Others: 175mm
CHAINRINGS
36/22, w/ alloy guard
BOTTOM BRACKET
SRAM PF30, OS press-in bearing, sealed cartridge
PEDALS
Resin Test Ride Pedals with toe clips, CEN std.
RIMS
Roval 29, alloy disc, 26mm wide, 32h
FRONT HUB
Specialized Hi Lo disc, laser-etched logo, OS 24 end caps, sealed cartridge bearing, RWS, 32h
REAR HUB
Specialized Hi Lo 142+ disc, laser-etched logo, double-sealed cartridge bearing, 12mm thru-axle, 32h
SPOKES
FRONT TIRE
Specialized Purgatory Control, 60 TPI, 2Bliss ready aramid bead, dual-compound, 29x2.2"
REAR TIRE
Specialized Ground Control, 60 TPI, 2Bliss ready aramid bead, 29x2.1"
INNER TUBES
SADDLE
Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm width
SEATPOST
2014 butted alloy, single bolt setback, 30.9mm, S/M: 350mm, Others: 400mm
SEAT BINDER
34.9mm clamp ID, alloy collar w/ QR, black
NOTES
Protective clear coat, derailleur hanger, reflectors, owners manual
Und hier die 2013:
RAHMEN
DÄMPFER
Custom Monarch RL with AUTOSAG, air spring, LO and rebound adj., 197x48mm
GABEL
RockShox Reba RL 29, Solo air spring, tapered alloy steerer, rebound adj., standard QR dropouts, 110mm travel
STEUERSATZ
1-1/8 and 1-1/2" threadless, Campy style upper with 1-1/2" lower, cartridge bearings
VORBAU
Specialized XC Trail, 6061 alloy, 4-bolt, 8-degree rise, 31.8mm clamp, 6-degree rise, S: 70mm, M: 90, L:100, XL:110mm
LENKER
Specialized XC Mini-Riser, 7050 butted alloy, 720mm wide, 10mm rise, 10-degree backsweep, 6-degree upsweep, 31.8mm
LENKERGRIFFE
Specialized Sip Grip, half-waffle aramid-infused, S/M: Regular, Others: XL thickness
VORDERRADBREMSE
Custom
Avid Elixir 3R, hydraulic disc, semi-metallic pad, HS-1 rotor S/M:180mm, Others: 200mm
HINTERRADBREMSE
Custom
Avid Elixir 3R, hydraulic disc, semi-metallic pad, HS-1 rotor S/M:160mm, Others: 180mm
BREMSHEBEL
Custom
Avid Elixir 3R, tool-less reach adj.
UMWERFER
SRAM X7, 10-speed, S3 direct mount for DMD, bottom pull
SCHALTWERK
SRAM X9, 10-speed, mid cage, Type 2
SCHALTHEBEL
SRAM X7, 10-speed, aluminum trigger, w/MatchMaker clamp
KASSETTE
KETTE
KMC X10, nickel plate, reusable Missing Link
KURBELGARNITUR
Custom
SRAM S-1250, 10-speed XC Trail double w/ alloy guard, PF30 spindle, S: 170mm, Others: 175mm
KETTENBLÄTTER
INNENLAGER
PEDALE
FELGEN
VORDERRADNABE
Specialized Hi Lo disc, OS28 end caps, sealed cartridge bearing, QR, 32h
HINTERRADNABE
New Specialized Hi Lo disc, 4x-sealed cartridge bearing, 142mm spacing, 12mm thru-axle, 32h
SPEICHEN
VORDERREIFEN
Specialized Ground Control, 2Bliss Ready, 60TPI, aramid bead, 29x2.3"
HINTERREIFEN
Specialized Ground Control, 2Bliss Ready, 60TPI, aramid bead, 29x2.1"
SCHLÄUCHE
Ultralight presta
SATTEL
SATTELSTÜTZE
Specialized 2014 butted alloy, single bolt setback, 30.9mm, S/M: 350mm, Others: 400mm
SATTELSTÜTZKLEMME
Specialized 7050 hard anodized alloy collar w/ QR, 34.9mm, black
ANMERKUNGEN
