das Bike ist 2003 und in XL wiegt es jetzt genau 11,95Kg wäre cool wenn eine 10 vorne steht, oder, was muss ich machen? Wieviel kostet das, sollte cool aussehen, alles mitmachen (>> NIX SID
)und bezahlbar sein...
Ach ja wiege ca. 72kg, also eher leicht
Fox Float F80RLC,
HEADSET 1 1/8" Threadless, 3x sealed, black alloy cups, cartridge bearings, ultralight alloy top cap and bolt
STEM Aluminum, 4 bolt, 7 degree rise, black
HANDLEBARS Specialized XC Low Rise bar, 2014 Alloy, 6 degree upsweep,
TAPE / GRIPS Specialized MTB grip, black, double density Kraton
BRAKES Magura Louise FR 2004
FRONT DERAILLEUR Shimano M-750 XT, 34.9mm clamp, bottom pull
REAR DERAILLEUR Shimano M-952 XTR, long cage, standard spring
SHIFT LEVERS Shimano M-965 XTR, STI integrated shifter/lever
CASSETTE Shimano M-750 XT, 11/34
CHAIN Shimano HG73
CRANKSET Shimano Deore XT, splined
CHAINRINGS 44Ax32Ax22A, 7050 alloy 4mm thick outer ring, 4 bolt
BOTTOM BRACKET Shimano ES-70 XT, Octalink spline, 68mm shell width
PEDALS Shimano 515 clipless
RIMS Mavic X317 disc, 26", black, welded seam, eyelets
FRONT HUB Specialized Stout disc, 32 hole, sealed cartridge bearings, 9mm Skraxle
REAR HUB DT Onyx disc, 32 hole, sealed cartridge bearings, alloy Q/R
SPOKES DT Swiss Super Comp 2.0/1.7/1.8mm butted stainless steel, alloy nipples, 261/264mm front, 262/262mm rear
TIRE Racing Ralph 2,25''
TUBES Specialized Ultralight, presta valve
SADDLE Specialized Body Geometry technology, leather cover, abrasion resistant corner panels, Titanium rails
SEAT POST Thomson, 7000 Series Aluminum, 2-bolt adjust, set back head, 30.9mm x 367/410mm
SEAT BINDER Alloy collar with Q/R, 34.9mm clamp I.D., black
Wieviel bringen FRM Wheels, gibt es für 359 bei...... ebay
Fox Float F80RLC,
CHAIN Shimano HG73
