Apeman
I'll be a monkey's uncle.
Hallo Gemeinde,
entlich ist es soweit. Ich stehe kurz vor meiner Kaufentscheidung.
Einsatzbereich: Touren/Endurotouren <40km auch mal in Bozen, ab und an auch mal ein Paar kleinere Kicker und Drops (evtl mal soften Bikepark-einsatz). Für härtere sachen hab ich ein Bergamont Big Air.
Specialized Pitch Comp: http://www.biker-boarder.de/shopwar...m_campaign=googleBaseDE&campaign=googleBaseDE
AUSSTATTUNG:
RAHMEN: 2009 Pitch frame, M4 tubing, double ORE downtube, DMD front derailleur mount, sealed cartridge bearing pivots, replaceable hanger, bolt on cable guides, 150mm travel
FEDERBEIN: X Fusion 02R, Custom tuned for Specialized, rebound adj., 7.875x2.25"
GABEL: Rockshox Pike 327 for Specialized, 140mm travel, coil U-Turn, alloy steerer, rebound adj., Maxle 360 included
STEUERSATZ: 1-1/8" Threadless, loose ball bearings w/ seals, black steel cups
VORBAU: Specialized, 8 deg. rise, four bolt 31.8mm clamp, 3D forged. S:60mm, M/L:75, XL:90mm
LENKER: Specialized mid rise 31.8mm, 6061 alloy, 660mm wide, 8 degree up, 8 degree back sweep
LENKERGRIFFE: Specialized thin lock on grip, alloy bar ends
VORDERRADBREMSE: Avid Juicy 3 SL, hydraulic disc, alloy backed organic pads, cleansweep 203 mm rotor
HINTERRADBREMSE: Avid Juicy 3 SL, hydraulic disc, alloy backed organic pads, cleansweep 185 mm rotor
BREMSHEBEL: Avid Juicy 3 SL Hydraulic
UMWERFER: Shimano SLX FD-M660, E-Type
SCHALTWERK: SRAM X-7, 9-speed, mid cage
SCHALTHEBEL: SRAM X-5, trigger, 9-speed
KASSETTE:Shimano HG -50, 9-speed, 11-34t
KETTE: KMC X9, 9-speed w/ reusable Missing Link
KURBELSATZ: Shimano FC-M442-8, Octalink Spline, replaceable rings w/ alloy outer, S: 170mm, others: 175mm
KETTENBLÄTTER: 22S x 32A x 44A, 4-bolt, 104/64mm
INNENLAGER: Shimano BB-ES25, Octalink spline, cartridge bearking, 68mm x 118mm
PEDALE: Specialized, 1pc., alloy body and cage, 9/16"
FELGEN: DT Swiss 445D, disc, 24mm, double wall, pin joint, eyelets, 32h
VORDERRADNABE: Specialized Stout disc, sealed cartridge bearing, 20mm thru axle, high/low flange, 32h
HINTERRADNABE: Specialized disc, sealed cartridge bearing, high/low flange w/ OS contact side, 32h
SPEICHEN: 1.8mm (15g) stainless, black, alloy nipples
VORDERREIFEN: Specialized Eskar Sport, 26x2.3", 60 TPI , wire bead
HINTERREIFEN: Specialized Eskar Sport, 26x2.3", 60 TPI , wire bead
SCHLÄUCHE: Specialized 26x2.0", schrader
SATTEL: Specialized Enduro, 7mm steel rails
SATTELSTÜTZE: Specialized 6061 alloy, black, 30.9x350, setback head, 2-bolt micro adjust
SATTELSTÜTZKLEMME: Alloy collar w/ QR, 34.9mm clamp ID
oder
Commencal Meta 5.5.3: http://www.tradoria.de/p/commencal-meta-5-5-3-komplettrad-2009-23449537
Commencal - Komplettbike Meta 5.5.3 Komplettrad 2009 Technische Daten:
Rahmen: Updated META 5.5 140mm frame New front/ Updated swingarn
Dämpfer: Fox Float R
Federgabel: Rock Shox Revelation 409 Dual Air Motion Control 140mm
Vorbau: Race Face Ride XC oversize
Lenker: C 1.5 " 6061 DB oversize
Griffe: C Kraton
Hebel: - Bremsen: Avid Juicy 3 180/160
Schaltung: Sram Trigger X7 3x9
Kettenfü, hrung: - Kurbeln: Truvativ Firex Giga X Pipe 44x32x22
Sattelstütze: Race Face Ride XC
Sattel: SDG Bel Air Black &, White
Naben: C disc brake / Shimano M475
Felgen: Jalco double wall disc specific white powder coating
Reifen: Hutchinson Barracuda Python 26x2.10 Farbe: Gloss Black
Würde beide für den gleichen Preis bekommen
Hab mich schon in den großen Freds zu den beiden Bikes eingelesen, kann mich aber leider nicht wirklich entscheiden.
Würde am liebsten beide kaufen...geht aber leider nicht.
Welche erfahrungen habt ihr mit den Bikes von 2009?
Welches würdet ihr mir empfehlen?
Grüße Apeman
AUSSTATTUNG:
oder
Griffe: C Kraton
Grüße Apeman
