Hallo
suche jemanden der vielleicht sein Freeride/DH Bike tauschen will!
Angeboten wird von mir ein Specialized Pitch Comp 2009.Gekauft habe ich das Bike im Mai 2009 für 1699.
AUSSTATTUNG:
RAHMEN
2009 Pitch frame, M4 tubing, double ORE downtube, DMD front derailleur mount, sealed cartridge bearing pivots, replaceable hanger, bolt on cable guides, 150mm travel
FEDERBEIN
X Fusion 02R, Custom tuned for Specialized, rebound adj., 7.875x2.25"
GABEL
Rockshox Pike 327 for Specialized, 140mm travel, coil U-Turn, alloy steerer, rebound adj., Maxle 360 included
STEUERSATZ
1-1/8" Threadless, loose ball bearings w/ seals, black steel cups
VORBAU
Specialized, 8 deg. rise, four bolt 31.8mm clamp, 3D forged. S:60mm, M/L:75, XL:90mm
LENKER
Specialized mid rise 31.8mm, 6061 alloy, 660mm wide, 8 degree up, 8 degree back sweep
LENKERGRIFFE
Specialized thin lock on grip, alloy bar ends
VORDERRADBREMSE
Avid Juicy 3 SL, hydraulic disc, alloy backed organic pads, cleansweep 203 mm rotor
HINTERRADBREMSE
Avid Juicy 3 SL, hydraulic disc, alloy backed organic pads, cleansweep 185 mm rotor
BREMSHEBEL
Avid Juicy 3 SL Hydraulic
UMWERFER
Shimano SLX FD-M660, E-Type
SCHALTWERK
SRAM X-7, 9-speed, mid cage
SCHALTHEBEL
SRAM X-5, trigger, 9-speed
KASSETTE
Shimano HG -50, 9-speed, 11-34t
KETTE
KMC X9, 9-speed w/ reusable Missing Link
KURBELSATZ
Shimano FC-M442-8, Octalink Spline, replaceable rings w/ alloy outer, S: 170mm, others: 175mm
KETTENBLÄTTER
22S x 32A x 44A, 4-bolt, 104/64mm
INNENLAGER
Shimano BB-ES25, Octalink spline, cartridge bearking, 68mm x 118mm
PEDALE
Specialized, 1pc., alloy body and cage, 9/16"
FELGEN
DT Swiss 445D, disc, 24mm, double wall, pin joint, eyelets, 32h
VORDERRADNABE
Specialized Stout disc, sealed cartridge bearing, 20mm thru axle, high/low flange, 32h
HINTERRADNABE
Specialized disc, sealed cartridge bearing, high/low flange w/ OS contact side, 32h
SPEICHEN
1.8mm (15g) stainless, black, alloy nipples
VORDERREIFEN
Specialized Eskar Sport, 26x2.3", 60 TPI , wire bead
HINTERREIFEN
SCHLÄUCHE
Specialized 26x2.0", schrader
SATTEL
Specialized Enduro, 7mm steel rails
SATTELSTÜTZE
Specialized 6061 alloy, black, 30.9x350, setback head, 2-bolt micro adjust
SATTELSTÜTZKLEMME
Alloy collar w/ QR, 34.9mm clamp ID
AUSSTATTUNG:
RAHMEN
FEDERBEIN
GABEL
STEUERSATZ
VORBAU
LENKER
LENKERGRIFFE
VORDERRADBREMSE
HINTERRADBREMSE
BREMSHEBEL
UMWERFER
SCHALTWERK
SCHALTHEBEL
KASSETTE
KETTE
KURBELSATZ
KETTENBLÄTTER
INNENLAGER
PEDALE
FELGEN
VORDERRADNABE
HINTERRADNABE
SPEICHEN
VORDERREIFEN
HINTERREIFEN
SCHLÄUCHE
SATTEL
SATTELSTÜTZE
SATTELSTÜTZKLEMME
