Die UST-Felgen sind auch mit den herkömmlichen Schlauchreifen kompatibel, so stehts bei Mavic
Mounting tube type tyres on UST Tubeless wheels
The UST norm has been validated by the European Tyre and Rim Technical Organisation (ETRTO) committee. By now, it is possible to mount tube type tires on UST Tubeless wheels if necessary. This option is authorised but eliminate all the advantages of the Tubeless system which provide better traction, less flats and better performance. With a tube, the use of rim tape is useless because the upper bridge of the profile is not drilled for spokes nipples thanks to our Fore concept.
Gruß Martin
Gruß Martin
