Übersicht Stahlrahmen
ylfcm
teh ownji
19. April 2003
3.951
Erfordia
Bike der Woche
Bike der Woche
On-One The Gimp
Tubing - DN6 Double Butted Chromoly
Frame size - 14"
tire clearance - 24in x 3.0in/26 x 2.7in
Top Tube length - 22"
Headtube length - 135mm
Head Angle - 71°
Seat Angle - 73°
Chainstay length - 16.5-18in
BB Height - 12"
Ideal fork length - 100-135mm
Seatpost Size - 27.0mm
Seatclamp - 29.8mm
USBB
€340
Planet-X Bommer
Tubing - DN6 chromoly.
Frame size - 14in
Top tube length - 22.5in
Headangle - 71° @ 80-100mm
Chainstay length - 16.7in
BB shell - 68mm
Seatpost size - 27.0mm
EuroBB
3080g
€420
Planet-X Pitbull
Seat post - 27.2mm
Seat post clamp - 30.0mm
Umwerferklemme - 30.0mm
EuroBB
€300
.243 Racing
Frame size - 13"
Top tube length - S / 21.5" , M / 22.5 , L / 23.5
Chainstay length - 15.7" - 16.5"
head angle - 69° w/ 5" fork
seat angle - 72° w/ 5" fork
BB shell - 68.0mm
Seatpost size - 26.8mm
Umwerferklemme - 28.6mm
USBB
3400g
€500
DMR Trailstar
Frame size - 14”
Top tube - 22.5”
Head angle - 71°
Seat angle - 72.5°
Vertical dropouts with MTB BB shell or horizontal dropouts with BMX BB shell
Federgabel - 80-100mm
Chainstay length - 419mm
Head tube length - 110mm
Wheelbase - 1033.3mm
USBB oder EuroBB (siehe oben)
2500g
€350
DMR Trailstar LT
siehe DMR Trailstar, aber auf 130mm Gabeln abgestimmt.
EuroBB
2500g
€350
DMR Rythm
Frame size - 12"
Chainstay length - 401mm
Seat tube length - 350mm
Top tube length - 556.5mm
Wheelbase - 1015.8mm
USBB
2500g
€350
Balfa Minuteman
Frame size - 13"
Top tube length - 22" oder 23"
tire clearance - 26in x 2,5in
head angle - 69°
seat angle - 72°
EuroBB
2900g
€800
ps: es gibt noch etliche weitere rahmen. da ich allerdings jetzt kein bock mehr hab, liegt es an euch die liste zu vervollständigen
Re: Übersicht Stahlrahmen
Da Bomb CR8
DIRT-JUMP Cr-Mo FRAME
Double-butted 4130 cr-mo Tube Disk Brake mount Ready Gusset double as bottle opener , Adjustable brake mounts for 24"-26" WheelSize: 13"/15"(c-t)
Color: black/olive/white
Preis: 299€
BRAVE MACHINE 22
>CrMo frame
>Horizontal verschiebbare Ausfallenden
>V-Brake Wiederlager für 24" und 26"
>Gewicht: 2,65 kg
GEOMETRIE
>Sattelstützen-Ø: 26.8mm
>Sattelklemme: 28.6mm
>Tretlagerbreite: 68mm (Euro BB)
>Oberrohrlänge: 545mm (21 inch)
>Rahmenhöhe: 13 inch
>Kettenstrebenlänge: 420mm
>Steuerrohrlänge: 115mm
BRAVE MACHINE 11
von der geo her fast das gleiche wie das 22, nur mit vertikalen ausfallenden und die die sattelstreben sind etwas anders.
coole Idee :daumen:
Orange Hitman
14" Euro 395.00
vertikale Ausfallenden 26"
Alutech
DDU_ Steel
Gewicht_ ab 2.900g
Material_ CrMo 4130
Innenlagergehäusebreite_68mm
Steuerrohr_110mm; 1.8"
Größen_one size fits it all
North Shore Extreme ,streetlegal
24 und 26" ,CR-MO, pegboses, horizontal dropouts(8mm), bmx BB, 10 oder 14mm hubs.Man kann gyro montieren.
wie wäre es mim last rufus :)
Größen: 26", M & L
Reifen: 24-26", 74mm Reifenfreiheit
Ausfallende: 10mm BMX
Preis: 699,-
Und nicht zu vergessen, der NPJ Budda 4130
Verticale Ausfallende mit intrigierten Kettenspannern aus 4130 CroMoly.
-double butted wärmebehandeltes Ober- & Unterrohr
-CNC gefrästes Steuerrohr
Steuerrohr: 71°
Sitzrohr: 72°
Oberrohr: 545mm (21,5")
Kettenstrebe: 418mm (16,45")
Gewicht : 2,7 Kg
Preis: 499,- Euro
NPJ
Budda
Geometrie:
Lenkwinkel: 71°
Sitzwinkel: 72°
Oberrohr: 545mm (21.5")
Kettenstrebe: 418mm (16.45")
Sattelstützenmaß: 25.4mm
Gewicht: 3.2 kg
ca. 350€
Last
Rufus
24"/26" 74mm Reifenfreiheit
BMX BB
Horiz. Dropouts
ca. 700€
KeeWee
cromoZONE
9.25" Rising Rate Suspension
Integrated Headset (no aftermarket headset needed)
Fifth Element Shock, 3" Stroke
Oversized Down Tube
4130 Cromoly US Mill Spec T - 67368
DH/FR settings
Weight: 42 pounds (built as race bike as shown)
Head Angle 66 degrees
Bottom Bracket Height 14"
Triple Chain Ring compatible
Fork Stops
Frame Size: Small 21", Large 22, XLarge 23"
Frame Colour: Gloss Black, Ferrari Red, Natural
Available also as a frame/fork/brake package
cromoEIGHT
8" Rising Rate Suspension
Fox Vanilla RC Rear Shock, 2.75" stroke
Built in Chain Guide, attached to the rear triangle
Hard roller bearing pins to increase pivot life
Head Angle 67 degrees
Bottom Bracket Height 14.5"
Adjustable Seat Tower allowing for Frame Sizes: Small - 20", 20.5", 21"/ Large - 21", 21.5", 22"
Frame Colour: Gloss Black, Candy Blue, Ferrari Red, Natural
cromoTOZE
Adjustable 5" - 7" of rear travel
Manitou Swinger SPV 2.75"
Head Angle 6" fork 68 degrees & 5" fork 69 degrees
Triple Chain Ring or Single chain ring
3-year warranty
progerssor
Adjustable vertical dropouts (a standard MTB style dropout that is horizontally adjustable allowing for single speed chain tensioning and wheelbase adjustment).
The frame has international standard chain guide mounts
Triple chain ring compatible.
Intergrated Headset (no aftermarket headset needed)
Head Angle 69 degrees (4" forks) 68 degrees (5" forks)
Super Strong Oversized Chain Stays
Adjustable Pivot use for 24" or 26" Wheels
3" Tyre Clearance
Bottom Bracket Height 12.5"
Frame Size: 21" top tube length
Frame Colour: Gloss Black, Battleship Grey
Marzocchi or DJ2
Wide Open Disc Brakes
stealth
3" Tyre Clearance
Frame Size: 13" (shown) and 15" -- 21" top tube length
Frame Colour: Gloss Black, Pearl White
Endless
Lifetime
14"
23" Headtube
Horizontal dropouts
Chainstays 15 3/4" to 16 1/2" With 24" front and rear wheel
70.5 degree head angle and seat angle
CMP
Firestarter
Umwerfermaß: 34.9 TopPull
Sattelstützenmaß: 31.6mm
Rahmenhöhe |Steuerrohrlänge |Oberrohrlänge:
35cm |125mm |530mm
40cm |125mm |555mm
Steuerrohr und Sitzwinkel: 70°
Tretlagergewinde: BSA 68mm
ca. 170€
Dual Faces
Steel
24"/26"
Wunschfarbe
ca. 190€
REVELL 250R
Dual MTB 24 inch Frames
24" frame reinforced head tube
and bottom bracket
100% 4130 cromo tubing
Horizontal drop-outs with chain tugs
and replaceable derailleur hanger
MTB/Euro bottom bracket
Disc brake mounts
Colors: Light Grey (pictured) or Dark Grey
$450.00 + shipping
Light Grey -Part No. R3010LG
Dark Grey -Part No. R3010DG
Custom Frame -Part No. R3010CS
REVELL 450R
Dual MTB 26 inch Frames
26" wheel frame reinforced head tube
and bottom bracket
Disc brake mounts
$450.00 + shipping
Light Grey -Part No. R3012LG
Dark Grey -Part No. R3012DG
Custom Frame -Part No. R3012CS
Infos gibts HIER
Spot Brand - Dirt Jumper:
- Material: 4130 CroMoly
- horizontale Dropouts, 135mm
- Sattelrohr: 14”
- Steuerrohr: 11cm
- Oberrohr: 54mm
- Kettenstrebe: 42mm
- Tretlagerhöhe: 31,5mm
- Steuerwinkel / Sitzwinkel:69° / 71°
- Sattelstütze 27,2 mm
- Tretlager 68 mm BSA
Preis: 555€
Seat Tube 12” (305)
Fork Range Rigid or 3"-7"
Rider Height (approx.) 4’8” - 5’4”
Stand Over Height (approx.) 24.25” (616)
Horiz. Top Tube 21.5” (546)
Chainstay Length 15.75” - 17” (
Wheel Base 39.9” (1015) 41” (1043) 41.9” (1064)
Frame Weight 6,7lbs
427$
DMR - Sidekick:
- ausgelegt für 80-100mm gabeln
- ausgelegt für 26" und 24" Laufräder
- Frame size: 12”
- Head angle: 71°
- Seat angle: 72.5°
- Top tube: 21”
-erhältlich als MTB-Version mit Euro-BB und vertikalen dropouts und als BMX-Version mit BMX-BB und horizontalen dropouts.
Preis: 350€
hi, sorry für die zwischenfrage, aber hat das brave 22 standartmäßig die schwarzen ausfallenden und die kettenspanner ??
hab bisher nur immer bilder von ner anderen version gesehen, mit gleichfarbigen ausfallenden und ohne kettenspanner..
Danke !!
Bis dann.
Moin,
Specialized P.Street:
4130CroMo Double Butted.
Komplettrad: 1099€
nur 24".
Lenkwinkel: 69,5°
Oberrohrlänge: 583mm
Sitzwinkel: 72°
Kettenstrebe: 391mm
Radstand: 1.050mm
wiegt: sehr schwer.
Sitzrohrlänge: (hab ich gemessen) 28,5cm
Und wenn ihr Fans von breiten HR seit, muss ich euch enttäuchen, da passen auch nicht mehr wie max. 2,1 24" rein :(
Moin,
Komplettrad: 1099€
nur 24".
Lenkwinkel: 69,5°
Sitzwinkel: 72°
Kettenstrebe: 391mm
Radstand: 1.050mm
wiegt: sehr schwer.
UrbanJumper schrieb:
Moin,
Komplettrad: 1099€
nur 24".
Lenkwinkel: 69,5°
Sitzwinkel: 72°
Kettenstrebe: 391mm
Radstand: 1.050mm
wiegt: sehr schwer.
ist ja au en streeter....;)
Was ist den hinten für ne Felge drin ?
Hinten und Vorne is ne Sun Rhyno Lite verbaut. Die is 29,5mm breit. Natürlich weiß ich das dass ein Streeter is :rolleyes: .........heißt ja auch P.Street :rolleyes: :rolleyes: :rolleyes: ;)
Superfly Styler
Das Bild ist noch ein Prototyp. Der Rahmen kommt in der Serie mit einer Aufnahme für Kettenführungen im ISCG Standard und OHNE Canti Sockel
Technische Details:
One Size Only !! RH= 38cm (gemessen Mitte Tretlagergehäuse bis Oberkannte Sitzrohr)
Oberrohrlänge= 545mm (parralel zum Oberrohr gemessen)
Steuerrohrlänge 105mm
Kettenstreben länge= 405mm
Lenkwinkel= 69°
Sitzwinkel= 72°
Gewicht= ca. 2,9 Kg (je nach Oberflächenbehandlung, d.h. Chrom, 1- fach pulver, mehrfach pulver etc.)
Features:
Rahmenmaterial: Reynolds 520 am Hauptrahmen alle anderen Rohre 4130 CrMo
Steuerrohr: Wandstärke 4mm auf 2mm exzentrisch abgedreht für maximale stabilität und geringstmöglichem Gewicht
Yoke an den Kettenstreben für "fette Schlappen" und gute Kettenlinie (Reifendurchlauf 77mm, Kettenlinie 47,5mm möglich)
Ausfallenden mit 6mm!! Wandstärke und austauschbarem Alu Schaltauge
Rahmen wird immer mit Sattelstütze und Steuersatz ausgeliefert
Aufnahme für Kettenführung nach ISCG Standard (Truvativ etc.)
Preise:
Rahmen in einfarbiger Pulverung (fast alle RAL Farben möglich) incl. Sattelstütze und Steuersatz = 489.-€ (zzgl. Versand und Verpackung)
www.dirtcompany.com
Benest
Hatchet DH/DS
Dim. Description DH 200 DS 120
A Seat tube angle 65° 65°
B Head tube angle 66° 68°
C Upper tube lenght 523 mm / 20.6" 529 mm / 20.8"
D Seat tube lenght 400 mm / 15.7" 354 mm / 13.9"
E Chainstay lenght 420 mm / 16.5" 425 mm / 16.7"
F Recomm. front susp. travel 180-200 mm / 7"-7.8" 120 - 130 mm / 4.7" - 5.1"
G Bottom bracket height 380 mm / 14.9" 345 mm / 13.6"
H Head tube diameter Integraded 1 1/8" Oversize 31,8 mm / 1 1/8"
J Standover height 733 mm / 28.9" 675 mm / 26.6"
N Shock absorber axle base 235 mm / 9.3" 205 mm / 8"
Q Seat tube offset 66 mm / 2.6" 66 mm / 2.6"
S Seat tube diameter 29.8 mm / 1.2" 29.8 mm / 1.2"
T Rear susp. travel 200 mm / 7,8" 120 mm / 4.7"
W Wheell base 1 130 mm / 44.4" 1 090 mm / 42.9"
Na, da fehlt noch meins.
PlanetX New jack Flash in Stahl(Prototyp/Einzelstück)
24"/26" Canti fahrbar, Scheibenaufnahme, ISCG Kettenführungsaufnahme, MTB Innenlager, normale Ausfallenenden.
Und das beste, es ist zu verkaufen...
