Today i took a closer look at whats causing the little play on the levers from
@Lupicus
It is defo not lil bit too much sanding on the pivots. Btw my pivots still fit pretty snug in there. So not too much sanding anyway.
There is a visible tiny gap when the levers are installed (if u look from backside like on my pic below) , and this causes some play when wiggling axially ofc.
In my opinion there is little bit too much gap between levers and housing which causes a little bit of play. They have no tight fit in there. At least mine. Maybe the bearings could protrude lil bit more, or maybe levers machined lil bit thicker? idk
If you uninstall the little pivot you can see that there is too much gap. I can easily fit a thin spacer or maybe two in between. Then it is more snug.
Good thing is. Even with that little play, they feel great and much better then the standard ones. But more snug would be even better. But also possible that u won´t feel a difference...
Maybe i install some spacers in there to test some day.
DEUTSCH:
Wie ist das denn bei euch mit den Lupicus Hebeln, wenn der Bolzen nicht drin ist, oder auch mit? Komplett ohne Luft, und stramm drin? Könnt ihr den axial nicht bewegen in der Passung? Normal sollten die ja sehr stramm da rein gehen, damit es kein Spiel gibt. Ist bei mir aber definitv nicht der Fall. Gehen viel zu leicht da rein. Ist ja klar, dass es dann leicht wackelt.
