big hit fsr II
10. Juli 2005
Bamberg
hallo
was haltet hier vom neuen big hit fsr II ?? was sollte man verändern ??
hier mal ne teileliste
FRAME All new BigHit FSR, 6061 ORE TT/DT, full cartridge bearing, ISCG mount, asymetrical rear triangle, 26" F/R wheel, adjustable geometry
REAR SHOCK Fox Vanilla R coil, 8.75x2.5", 190mm travel
FORK Marzocchi Drop-Off Triple, 170mm travel, air assist, rebound adjustment, double clamp, 20mm thru axle
HEADSET 1 1/8" threadless, OS Cro-Mo cups
STEM Truvativ Hussefelt, forged/CNC stem, 5 degree x 40mm, 31.8 clamp, black
HANDLEBARS Specialized Demo rise bar, 6061 alloy, 31.8mm, 6 degree upsweep, 9 degree backsweep
GRIPS Specialized MTB grip, natural/black
FRONT BRAKE Avid Juicy 5, hydraulic disc brake 8" Polygon rotor
REAR BRAKE Avid Juicy 5, hydraulic disc with 8" Polygon rotor
BRAKE LEVERS Avid Juicy 5
FRONT DERAILLEUR None
REAR DERAILLEUR SRAM X-9, micro cage
SHIFT LEVERS SRAM X-7 Trigger, 9-speed
CASSETTE Shimano HG50, 9-speed, 11-34t
CHAIN SRAM PC-971 with Power Link
CRANKSET Truvativ Hussefelt, 170mm with Truvativ chain guide
CHAINRINGS 34T, 4 bolt, compact 104mm pattern
BOTTOM BRACKET Truvativ Howitzer XR, oversize sealed outboard cartridge bearing, 73mm shell
PEDALS Alloy platform, 3mm pressed pins, 9/16" Cr-Mo axle
RIMS Sun Single Track SL-1, 36 hole, 26" F/R, schraeder valve
FRONT HUB Specialized disc, 36 hole, 20mm thru axle
REAR HUB Specialized disc, 36 hole, bolt on axle, 135mm spacing
SPOKES 2.0mm (14g) stainless, black, brass nipples
FRONT TIRE Specialized Chunder 26x2.3" 60TPI, 2 ply, soft compound
REAR TIRE Specialized Chunder 26x2.3" 60TPI, 2 ply, soft compound
TUBES Specialized 26x2.4" schraeder valve
SADDLE Specialized freeride, 8mm steel rails, with X-Brace
SEAT POST Titec Scoper telescopic, 30.9, non-offset head
SEAT BINDER 7050 hard annodized alloy collar with QR, 34.9mm clamp ID, black
Servus.
Du solltest auf deine eigenen Vorlieben achten:
z.B. Sram Trigger?oder doch lieber Shimano Rapidfire!? Was ist mit ner Kettenführung? reichen 2,3" Reifen? Vanilla R?-ich fahr auch einen, aber mehr als Zugstufe und Vorspannung ist da nicht einzustellen (hat sicherlich Vor und Nachteile)!
Die Gabel wird auch nicht grad die beste sein und sollte nach den eigenen Vorstellungen und Fahrstil ausgewählt werden. Mit der Performance kommt sie an keine der großen Gabeln herran!
Alles andere klingt recht chic und harmonisch und bewährt hat sich das Bike ja auch schon über die Jahre.
Greetz JEndo
