m4:
teilenummern:
HBSP162 - 5mm/Braided 90 Deg Connector
HBSP026 - 6mm Sealing Washer (10off)
HBSP047 - 90 Deg connector Bolt
HBSP068 - M4/MM4/09MM4 Large Piston Seal
HBSP136 - MM4 Large/09 MM4 Piston
HBSP139B - MM4 Large/09 MM4 Bore Cap - Blue
HBSP139GO - MM4 Large/09 MM4 Bore Cap - Gold
HBSP139M - MM4 Large/09 MM4 Bore Cap - Gunsmoke
HBSP139N - MM4 Large/09 MM4 Bore Cap - Black
HBSP139R - MM4 Large/09 MM4 Bore Cap - Red
HBSP139S - MM4 Large/09 MM4 Bore Cap - Silver
HBSP140 - MM4 Large/09 MM4 Bore Cap 'o' Ring
HBSP141 - MM4 Standard Pads (pair)
HBSP141S - MM4 Sintered Pads (pair)
HBSP142 - MM4 Pad Spring
HBSP171 - Pad Pin Clip
HBSP204 - Pad Retention Pin
HBSP238 - 09 Bleed Nipple
HBSP239 - 09 Bleed Nipple 'o' Ring
HBSP240 - 09 Bleed Nipple Cap
HBSP241 - 09 MM4 Caliper Body
x2:
teilenummern:
HBSP162 - 5MM/Braided 90 Degree Connector
HBSP026 - M6 Sealing Washer (10 off)
HBSP047 - 90 Deg Connector Bolt
HBSP236 - X2 Caliper Piston Seal
HBSP235 - X2 Caliper Piston
HBSP243B - X2 Bore Cap - Blue
HBSP243GO - X2 Bore Cap - Gold
HBSP243M - X2 Bore Cap - Gunsmoke
HBSP243N - X2 Bore Cap - Black
HBSP243R - X2 Bore Cap - Red
HBSP243S - X2 Bore Cap - Silver
HBSP244 - X2 Bore Cap 'o' Ring
HBSP237 - X2 Pads Standard (pair)
HBSP237S - X2 Sintered Pads (pair)
HBSP202 - X2/Moto Caliper Pad Spring
HBSP234 - X2 Caliper Body
tech hebel:
HBSP163 - 5mm/Braided Straight Connector
HBSP213 - Tech Master Cylinder Piston
HBSP214 - Tech Master Cylinder Primary Piston Seal
HBSP215 - Tech Master Cylinder Secondary Piston Seal
HBSP216 - Tech Master Cylinder Dust Cover
HBSP220 - Tech Master Cylinder Blanking Plug
HBSP222 - Tech Master Cylinder Lever Pivot
HBSP223 - Tech Master Cylinder Lever Pivot Screw
HBSP224B - Tech Master Cylinder Lid - Blue
HBSP224GO - Tech Master Cylinder Lid - Gold
HBSP224M - Tech Master Cylinder Lid - Gunsmoke
HBSP224N - Tech Master Cylinder Lid - Black
HBSP224R - Tech Master Cylinder Lid - Red
HBSP224S - Tech Master Cylinder Lid - Silver
HBSP225 - Tech Master Cylinder Lid Diaphragm
HBSP226 - Tech Master Cylinder Clamp
HBSP227 - Tech Master Cylinder Special Cir-clip
HBSP228 - Dia5 x 1.5 o'ring EPDM Plug 'o'Ring
HBSP229 - Tech/Race Permaglide Flanged Bush Dia6
HBSP231 - Tech Piston Spring
HBSP245 - Tech Plastic Piston End
HBSP212 - Tech Master Cylinder Body
HBSP111 - M3 x 8 Torx Dome Head Screw (2off)
M516 - M5 x 16 Cap Screw
HBSP217 - Tech Master Cylinder Cam Pusher
HBSP218B - Tech Master Cylinder Lever Blade - Blue
HBSP218GO - Tech Master Cylinder Lever Blade - Gold
HBSP218M - Tech Master Cylinder Lever Blade - Gunsmoke
HBSP218N - Tech Master Cylinder Lever Blade - Black
HBSP218R - Tech Master Cylinder Lever Blade - Red
HBSP218S - Tech Master Cylinder Lever Blade - Silver
HBSP219 - Tech Master Cyliner BPC & Reach Adjuster Screw
HBSP221 - Tech Master Cylinder Brass Plunger
HBSP230 - Grub Screw Dog Point M4 x 5mm
HBSP232 - Tech Lever Spring
HBSP233 - Crescent Ring for Dia6 Shaft
wenn man auf der suche nach sowas ist, dann schau am besten immer zuerst auf der britischen hope seite. da gibt es eigentlich immer was man sucht.
