Per Spacer ist es nicht mehr möglich. Brauchst dann einen anderen Air Schaft.
Air Shaft Reba/SID B 120mm travel 27.5" (can be used to change travel to 120mm on 27.5" Solo Air, not compatible with 29" or Dual Air)
Air Shaft Reba/SID B 110mm travel 27.5"/29" (can be used to change travel to 110mm on 27.5"/29" Solo Air, not compatible with Dual Air)
Air Shaft Reba/SID B 100mm travel 27.5"/29" (can be used to change travel to 100mm on 27.5"/29" Solo Air, not compatible with Dual Air)
Air Shaft Reba/SID B 90mm travel 27.5"/29" (can be used to change travel to 90mm on 27.5"/29" Solo Air, not compatible with Dual Air)
Air Shaft Reba/SID B 80mm travel 27.5"/29" (can be used to change travel to 80mm on 27.5"/29" Solo Air, not compatible with Dual Air)
Air Shaft Reba/SID B 120mm travel 26" (can be used to change travel to 120mm on 26" Solo Air, not compatible with Dual Air)
Air Shaft Reba/SID B 110mm travel 26" (can be used to change travel to 110mm on 26" Solo Air, not compatible with Dual Air)
Air Shaft Reba/SID B 100mm travel 26" (can be used to change travel to 100mm on 26" Solo Air, not compatible with Dual Air)
Air Shaft Reba/SID B 90mm travel 26" (can be used to change travel to 90mm on 26" Solo Air, not compatible with Dual Air)
Air Shaft Reba/SID B 80mm travel 26" (can be used to change travel to 80mm on 26" Solo Air, not compatible with Dual Air)
All-Travel Spacer Kit (not compatible with SID/Reba/Revelation Solo Air Spring)
