Silikonspray und mit einer dünnen Ahle oder Stück Draht das abgebrochene Stück von oben (gegenrichtung zum Einbau) herausschieben, schon versucht?
(...and sorry for the english)
I have a 2018 Lux CF, which is actually the same as the 2014 version (except for some parts of the rear suspension and bearings, as far as I know).
I'm using its stock fork currently, which is a Fox 32 Elite StepCast, but I would like to 'convert' this bike to a more trail-capable bike and replace it to the new RS SID 29" 120mm travel fork with the 35mm stanchions, if it's possible.
How do you see, is this frame capable to handle a 120mm fork or should I reduce the travel back to 110 or 100mm (based on the 2021 RS SID .PDF file, it's possible)?
Many thanks for your help.
Thanks!Have look at this page, then you can see the geo changes: https://bikegeo.muha.cc/
