MONDRAKER - Foxy Carbon R oder Radon Slide 27,5 10.0
22. März 2014
72
Hi zusammen,
ich möchte mir ein neues Bike kaufen, zur Auswahl steht das "MONDRAKER - Foxy Carbon R" und das "Radon Slide 27,5 10.0"
Die Fakten des MONDRAKER - Foxy Carbon R:
FRAMEFoxy 27´5 Stealth Full Carbon Zero Suspension System FG 140mm
SIZESS / M / L / XL
REAR SHOCKFox Float CTD LV Boost Valve Performance 200x57mm
FORKFox 34 Float 27´5 CTD FIT Performance 15mm tapered 140mm
HEADOnoff Integrated tapered 1-1/8”->1/5”
STEMOnoff Stoic FG 30mm
HANDLEBARMondraker Foxy Carbon R custom design 1” 740mm
GRIPSOnoff Paw lock-on
SEATPOSTRockShox Reverb Stealth 31.6mm
SADDLEFizik Nissene Mg
FRONT BRAKEFormula CR3 180mm
REAR BRAKEFormula CR3 180mm
LEVERSFormula CR3
RIMSDT M1900 Spline 27´5 wheelset
SPOKESDT
FRONT HUBDT M1900 Spline 15mm
REAR HUBDT M1900 Spline 12x142mm w/DT RWS axle
TIRES Maxxis Ardent 27´5x2.40
CRANKSETShimano XT M-785 38/24T
BOTTOM BRACKETShimano Pressfit SM-BB71
PEDALS/
CHAINSram PC-1031 10s
FRONT DERRAILLEURShimano Deore SLX FD-M676D Direct Mount
REAR DERRAILLEURShimano XT RD-M786 SGS Shadow Plus 10s
SHIFTERSShimano SLX SL-M670 2x10s
CASSETTESram PG-1030 11-36T 10s
WEIGHT 12.7kg
Und hier die Fakten das Slide 10.0 27,5
Rahmen Radon Slide 150 27,5
Gabel Fox 34 Talas 27,5, CTD, Adjust, Fit, Kashima, taper, QR15
Dämpfer Fox Float CTD, Adjust, BV, Kashima, 200mm
Federweg Front 150mm
Federweg Rear 150mm
Laufradsatz Mavic Crossmax XL, 27,5", QR15/X12
Bremse Shimano XT K-M785
Bremsscheiben Shimano SM-RT56M 180/180mm, 6 bolt
Kurbel Race Face Turbine, 22/36, BSA, 175mm
Innenlager Race Face Turbine, BSA
Schalthebel Shimano XT SL-M780, Direct Attach
Umwerfer Shimano XT FD-M781, direct mount, downswing
Schaltwerk Shimano XT RD-M786-SGSL, Shadow Plus
Kassette Shimano SLX CS-HG81, 10-speed, 11-36
Kette Shimano Deore CN-HG54, 10-speed
Lenker Race Face Turbine 31,8, 760mm, 0.5" Rise
Vorbau Race Face Turbine Basic 31,8mm
Steuersatz Radon Pro taper
Griffe Ergon GE1 SD
Sattelstütze Rock Shox Reverb Stealth 31,6 x 420mm
Sattel Selle Italia Flite MG
Reifen Schwalbe Nobby Nic, TLE, Kevlar, 27.5 x 2.35"
Farbe black/anthracite/green
Gewicht 13,35 kg**
Rahmengrößen 16", 18", 20", 22"
Bei dem Radon sind die Läufrader Mavic Crossmax XL da liest man ja nicht überwiegend positives, was könnt ihr dazu sagen? Das Radon hat die Kashima Beschichtung bei Gabel und Dämpfer ist das so ein unterschied wenn man diese nicht hat, das Mondraker hat dies leider nicht.
Mondraker hat ein Carbon Rahmen und ist leichter als das Radon, kostet natürlich mehr (erhalte das Bike zu einem sehr guten Preis nicht weit mehr als das Radon würde es kosten).
Die Mondraker Bremse BRAKEFormula CR3 taugen die was?
Wäre super wenn einer mir kurz aufzeigen kann, was der Vorteil an dem Radon ist bzw. was der Vorteil an dem Mondraker ist.
Hier der Link zu dem Mondraker: http://www.mondraker.com/15/eng/bikes/foxy-carbon-r/390/gallery
Freue mich über eure Antworten.
Gegensätzlicher geht wohl kaum, da solltest du zuerst probefahren und dann nach Kashima oder nicht fragen.
Wenn du dazu keine Möglichkeit hast, glaub auf pinkbike war erst ein Test vom Foxy, sonst mal googeln.
cxfahrer danke für deine Antwort, habe den Test bereits gelesen, jedoch war der für das RR und XR. Probefahren das ist klar, jedoch möchte ich einfach vorweg ein paar oben genannte Fragen geklärt haben. Kannst du denn dazu was sagen, zu den Bikes oder den einzelnen Teilen an den Bikes?
Am Foxy ist eigentlich jedes Bauteil (von SLX/XT und Reverb abgesehen) untere bis unterste Schublade, also vergleichbar mit einem 1500.-€ Radon. Wenn einem der Rahmen das Wert ist, kann man damit sicher auch klar kommen.
Am Radon ist es allerdings so, dass ein bunter Strauß an blinbling Teilen verbaut ist, die jetzt nicht unbedingt viel besser funktionieren. Die 2015er FOX34 soll so oder so nicht so toll sein...der Rahmen ist halt total anders.
Ich kann mir irgendwie nicht vorstellen, dass man die vergleicht.
Radon "blinbling Teilen" ? Was möchtest du mir damit sagen. Wieso sollten die Teilen nicht besser funktionieren am Radon? Was gibt es dann als Ersatz für eine Fox34 / 2015 ? Kannst mir natürlich auch gerne ein ganz anderes Bike nennen, jedoch sind die 2 oben genannten eine Vorauswahl.
Die Bikes unterscheiden sich von der Geometrie sehr stark, das Mondraker ist viel länger und wird dafür mit einem kurzen Vorbau gefahren. Ich bin das Foxy XR mal probe gefahren und mir hat es als Trailbike gut gefallen. Ich fahre allerdings abfahrtsorientiert und schon viele Jahre. Ich weiß nicht ob die Geometrie vom Foxy für jeden ideal ist, da sollte man auf jeden Fall eine Probefahrt machen. Ansonsten gefällt mir das Foxy optisch viel besser, dafür würde ich persönlich bei den Komponenten Abstriche machen und vielleicht später mal was tauschen.
