My new triple light, The Beast!!!!
27. Oktober 2006
Lleida (Spanien)
Hi, here my new triple light, very, very easy of doing, how you can see, I hope that like us :)
I have used a square tuve of 40x40mm and PVC tube of external diameter of 40x40mm too.
Now glued the PVC tubes to the aluminium tube
Inside view, I have used too a "custom" inside heatsink how you can see
Glued the 3 leds to the aluminium tube (I have used 2 Cree Q5 and 1 Cree P4, I know that have was better use R2 leds, but was that I had :D )
I make holes in the square tube and I have soldered the cables...
Now I have solder the cables to the swich, drivers and power conection, I have used 3 drivers to can use a battery of only 7,4 volts :)
Another view
Rear view
Another view
Power supply put on the tube
Inside view
Switch put on the tube
Inside view
I have isolated the driver with....(sorry, but I don't know how it say in english "manguera termoretractil") :madman:
Another view
Another upper view
Bottom view, I have used a H-24 spacer from Cateye
Front view
Well, I still don't have ended the light, already don't have put the lateral caps, but I hope ended soon and put any beamshot :D
Gruss - Saludos
Jose
hey, nice light! :daumen:
Very easy to build - so perfect for anyone who want to build a diy light!!
I'm looking forward to see the beamshots!!
This looks even more terrible than my homemade 3-SSC-P4 . But it doesn´t matter . At night nobody can see if it is lowbudget and lowtime handmade or sinful expensiv ( I have forgotten the name of the manufactor ) .
Whitedog, Minutentourer Thanks to both for the comments, really it is easy of do. I know that the finished don't are goods...but the light are very functional, that was it that I wanted :)
Gruss - Saludos
Jose
Hey msxtr,
well done !
I would like to translate "manguera termoretractil" as soon as I understand the meaning of it :)
One questions and one suggestion in regard to your PVC tubing though:
Question: What kind of tubing did you use ?
Is this some sort of cable tubing ?
I mean typical electrical tubing ?
In general a pipe cuter helps a lot to do straight cut. Have a look here:
http://cgi.ebay.de/Kunststoff-Rohra...39:1|66:2|65:12|240:1318&_trksid=p3286.c0.m14
Or typically to cut anything up to 2.5 inch:
http://cgi.ebay.de/Ridgid-360-Rohra...39:1|66:2|65:12|240:1318&_trksid=p3286.c0.m14
Cheers,
Holger
ja, ich hoffe, das bild auf dem man die schrumpfschlauch-stücke lose über den ksqs sieht, ist nicht der letzte stand... vielleicht sollte ihm jemand sagen, dass man das zeug erhitzen muss, damit es schrumpft :D
Erinnert mich ein bisschen an mein Mobdar Triple.
Nur ich hatte mehr Arbeit mit dem Gehäuse :)
Hey msxtr,
well done !
Cheers,
Holger
Hi to all!!!!!!
Yes "manguera termoretractil" mean shrink tube, schrumpfschlauch :D;)
I have used PVC tube, normally it's to lead electric cables, I think...:rolleyes:
I have used to cut the tube a similar tool how you show.
anonymfixer Thanks for the traslation ;)
rob1111 your light are very, very much nice that my light :)
Gruss - Saludos
Jose
