hallo ich habe am wochenende nen 2007 sp. epic erstanden....ich werde das bike übern winter erstmal so fahren und möchte im frühjahr so nach und nach einzelne komponenten verbessern.
wo seht ihr am ehesten handlungsbedarf - über tips würde ich mich freuen !!
RAHMEN Epic FSR M5 alloy, fully manipulated frame w/ ORE DT/TT, hollow alloy shock link, sealed cartridge bearings, 100mm travel, replaceable derailer hanger
FEDERBEIN Specialized Fox Brain Fade, adjustable from HT firm to Trail Tune, air spring, rebound adjust
GABEL Fox F100 RL 100mm, air spring, rebound/compression adj w/ lock out, alloy steerer
STEUERSATZ 1 1/8" Threadless, alloy cups w/ 10mm insertion, sealed cartridge bearing
VORBAU Specialized adjustable rise, OS 31.8, 3D forged w/CNC finish
LENKER Specialized XC low rise 31.8mm OS bar, 2014 butted alloy, 6 degree up, 8 degree backsweep, 620mm width
LENKERBAND/GRIFFE Specialized MTB, dual density
VORDERRADBREMSE Avid Juicy 5, hydraulic disc, G2 Clean Sweep S/M: 160mm rotor, L/XL: 180mm rotor
HINTERRADBREMSE Avid Juicy 5, hydraulic disc, G2 Clean Sweep 160mm rotor
BREMSHEBEL Avid Juicy 5
UMWERFER Shimano M581 LX, 34.9mm clamp, bottom swing, dual pull
SCHALTWERK SRAM X.9, 9-speed, long cage
SCHALTHEBEL SRAM X-7, aluminum trigger 9-speed
CASSETTE / FREEWHEEL Shimano HG50, 9-speed, 11/34t
KETTE SRAM PC-951 w /Power Link
KURBELSATZ Truvativ Stylo, 2pc crank/BB
KETTENBLÄTTER 22S/32A/44A 4mm thick outer, 4 bolt 104/64mm
BOTTOM BRACKET Truvativ GXP, sealed outboard cartridge bearing
PEDALEN Shimano M-520 SPD
FELGEN DT Custom for Specialized X430, 24mm w/eyelets, 32h
VORDERRADNABE Specialized Stout disc, sealed cartridge bearing, high/low flange, 32h
HINTERRADNABE Shimano M-525 disc, 32h, alloy QR
SPEICHEN DT Swiss 1.8mm stainless, black, alloy nipples
VORDERREIFEN Specialized Fast Trak Pro 26x2.0", aramid bead, dual compound
HINTERREIFEN Specialized Fast Trak Pro 26x2.0", aramid bead, dual compound
SCHLÄUCHE Specialized Ultralight 26x2.0", presta
SATTEL Specialized BG Rival, hollow Cro-Mo rails
SATTELSTÜTZE 2014 butted alloy, black, 30.9 x 350/400mm
SATTELSTÜTZKLEMME 7050 hard annodized alloy collar w/ QR, 34.9mm clamp ID, black
ANMERKUNGEN Protective clear coat, derailleur hanger, reflectors, owners manual
