RCZ-Glaskugel: Wartezimmer, Spekulationen, Austausch
Re: RCZ-Glaskugel: Wartezimmer, Spekulationen, Austausch
Versteht irgendjemand diese technische Angabe bei der angebotenen GRX-Bremse?
FOR 25MM MNT im Gegensatz zu FOR 20MM MNT bei der gleichzeitig angebotenen anderen Bremsenkombi?
Google sagt:
The term "flat-mount" in relation to disc brakes refers to a specific mounting system for brake calipers. It's a more modern and streamlined system compared to older post-mount systems. The numbers 20mm and 25mm, when used in conjunction with "flat-mount," typically refer to the thickness of the frame or fork section where the brake caliper is mounted.
20mm Flat-Mount:
  • This refers to a flat-mount disc brake system designed for frames or forks with a 20mm thick mounting surface.
  • It's a common standard, especially for smaller, lighter frames and forks in road bikes and some lightweight mountain bikes.
25mm Flat-Mount:
  • This refers to a flat-mount disc brake system designed for frames or forks with a 25mm thick mounting surface.
  • It's a more common standard for thicker frames and forks, often found in mountain bikes and some larger road bikes.
Key Differences:
  • Frame Thickness:
    The primary difference between 20mm and 25mm flat-mount is the thickness of the frame or fork section that the brake caliper mounts to.
  • Strength and Stiffness:
    Frames and forks with thicker mounting surfaces (e.g., 25mm) are typically designed to offer more strength and stiffness, which can be beneficial for heavier bikes or riders or for more demanding riding conditions like mountain biking.
  • Compatibility:
    You need to ensure that your brake caliper and frame or fork are both compatible with the specified flat-mount standard (20mm or 25mm) for proper installation and function.
In summary, the 20mm and 25mm refer to the mounting surface thickness. While both are flat-mount systems, the thicker 25mm option is generally more robust and suited for heavier bikes or riding styles.
Wieso geht bei der silbernen Cura eigentlich immer noch der Warenkorb Button? Waren doch laut NL nur 10 Stück ..... ich will nicht noch eine zweite kaufen ^^
Das ist interessant! Wusste gar nicht, dass zwei unterschiedliche Bremssätteltypen für Flatmount existieren und dachte bisher, dass Variationen über einen entsprechend hohen Flatmountadapter gelöst würden.
Aber was heißt das denn nun konkret? Dass ein für 25mm-Montageaufnahmen konstruierter Bremssattel nicht an eine 20mm-Rahmenaufnahme montiert werden kann (und umgekehrt), oder heißt es nur, dass zwar montiert werden kann, dann aber die Abstände der Beläge zur Bremsscheibe nicht mehr stimmen? Das sind ja zwei verschiedene Stiefel.
Fotos dieser unterschiedlichen Bremssättel für 20 und 25mm hat dir Google nicht zufällig geliefert?
ich würde KI generierte Infos auch immer mit Vorsicht genießen. Die fantasieren lieber was zusammen bevor sie sagen, dass sie die Frage nicht beantworten können.
Kann also richtig sein, muss es aber nicht.
In diesem Fall dürfte es passen. Wenn ich es richtig verstanden habe geht es vor allem um die Länge der Schrauben zum Befestigen des Bremssattels.
:awesome:
