Frame : NINER RDO CARBON FIBER – INTERNAL CABLE ROUTING; INTEGRATED BOTTLE, BAG, RACK AND FENDER MOUNTS; FLAT MOUNT; 12X142 THRU AXLE
Fork : NINER RDO FULL CARBON – INTEGRATED BOTTLE, BAG, RACK AND FENDER MOUNTS; INTERNAL CABLE ROUTING; FLAT MOUNT; 12X100 THRU AXLE
Shock : N/A
Front Wheel : DT Swiss G 1800 SPLINE 25, 700c aluminum clincher, centerlock, 100x15mm
Rear Wheel : DT Swiss G 1800 SPLINE 25, 700c aluminum clincher, centerlock, 142x12mm
Front Tire :
SCHWALBE G-ONE ALLROUND EVO SUPER TERRAIN, TLE, ADDIX SPEEDGRIP, 700 X 45
Rear Tire :
Brakes :
SRAM RIVAL 1 HRD FM
Brake Levers :
SRAM RIVAL 1 HRD
Brake Rotors :
SRAM CENTERLINE 160/160MM CL ROTORS
Chain :
SRAM PC 1130 11SP
Front Shifter :
SRAM RIVAL 1 HRD
Rear Shifter :
SRAM RIVAL 1 HRD 11SP
Front Derailleur : N/A
Rear Derailleur :
SRAM RIVAL 1 LONG CAGE
Cassette :
SRAM PG 1130 11SP 11-42T
Crankset : EASTON EA90 40T (47/50 - 170MM, 53/56 - 172.5MM, 59/62 - 175MM)
Bottom Bracket : EASTON PF30
Saddle : NINER CUSTOM WITH CR-MO RAILS, EMBOSSED NINER GRAPHIC
Seatpost : NINER CARBON SEAT POST, 400MM, NINER GRAPHIC
Handlebar : EASTON EC70 AX (47/50 - 420MM, 53/56 - 440MM, 59/62 - 460MM)
Stem : NINER ALLOY STEM, NINER GRAPHIC (47/50 - 80MM, 53/56 - 90MM, 59/62 - 100MM)
Grips : NINER BAR TAPE
No Frame / No Rear Shock / No Wheels/no headset
