TIPP: Gleich in die Vollen gehen und die 190 mm Federweg wählen!
Denn in Sachen Wippen oder Vortrieb steht die 190 mm Variante der 165 mm Variante in Sachen Vortrieb kaum nach. Aber bergab legt die 190 mm Variante noch mal eins drauf.
Steht auf der Liteville Hp,
war gerade zu faul zum Ãbersetzen, Google passt zwar nicht immer ganz:
TIP: go to the full and equal choose the 190 mm ââtravel!
Because when it comes to driving rockers or is the 190 mm ââversion of the 165 mm version in terms of driving not far behind. But lays down the 190 mm ââversion on it one more time.
my experience;
The 160mm versions is enough for all mountain riding up to some stronger descending. It efficiently pedals up with the advantage that you will have less bob than the 190mm version. I really do not come short on 'compensation' in the 160mm version. Testing the 190 it indeed felt more plush on your way down, but you will be dancing a bit more on your way up...
Bottom line: when you want a bike that is more 'one bike for all' I would go for a 160 setup; when you focus is on the descents/bike parks - go big...
I have a coil damper .... CCDB in 240 mm for Parck bike use ... ...
But , for use in single trails and small jump´s with curves and search of flow...... is preferable : 222 or 240 mm ???
No one will be able to give you the one and only answer for that question
You will probably get the same number of different oppinions as the number of people you ask.
The long damper will make the bike more plush, more adapted to bike park use or for really heavy terrain. The short damper will make the bike more agile and quicker in handling.
Liteville proposes to go for the 241mm version. I personally would rather choose the 222mm version
Both options will give you a very fine ride for the purpose you described. Which one you prefer...? You will have to decide yourself!
