Rebbit_Cro
Keep riding.
Few months ago i bought 2009/2010(not sure) RS Reba SL Dual Air 100mm. Seller says it is OEM fork (specialized).
I gave to guy who just had to remove 20mm spacer so i can have 120mm Reba (ATC issues). But, unfortunately, it doesn't work. works excellent on 100mm, but when it is on 120mm i have issues mentioned below:
So, if you pump positive chamber (let say 80PSI) the stanchions go out for about 125mm, but when you pump negative chamber (to35-40PSI) it is all good, but if you pump negative over 40PSI (so, more than 50% of + chamber), the fork sucks up the stanchions for about 2cm (or if it doesn't, when I touch the handlebar fork just drops for 2cm). If you pump even more, up to 80/80. the fork will be max 95mm of travel, and it will work like sh...t..
It was reasembled 2-3 times after the issue found but nothing helped, then returned to 100m and works like a charm...
Did someone find out what could cause this issues?
Regards.
Regards.
