Specialized FSR XC Pro <> Stevens F9 LITE
Dr.Watt
It's a Hardtail's Night
9. August 2005
Stuttgart (Süd)
Gut'n Morgen...
ich benötige mal eine Kaufberatung für nen Kumpel. Er steht vor der schweren Wahl zwischen zwei Bikes und würde gerne wissen "was für das jeweilige Bike spricht und was dagegen". Hier die Daten...
Specialized FSR XC Pro Disc Modell 2005
FRAME FSR technology, A1 Premium Aluminum butted frame, ORE toptube and downtube, sealed cartridge bearings, disc only, 100mm travel, replaceable derailleur hanger, two sets of water bottle bosses
REAR SHOCK Fox Float Triad. Custom on-the-fly three position switch 1) Lock-out, 2) Open, 3) ProPedal pedal assisting damping. External rebound adjust, Twin sleeve design for increased volume. 6.5x1.5”
FORK Manitou Splice Elite, 100mm travel, rebound adjust, compression lock-out, disc only, alloy steerer
HEADSET 1 1/8” threadless, black steel cups, loose ball bearings with seals
STEM 3D forged CNC machined, 4 bolt, 31.8mm OS clamp, 8 degree rise
HANDLEBARS Specialized XC Low Rise 31.8mm OS bar, 6066 butted alloy, 6 degree upsweep, 8 degree backsweep, 640mm width
TAPE / GRIPS Specialized MTB grip, black, double density Kraton
FRONT BRAKE Shimano M-525 full hydraulic disc, 6” rotor
REAR BRAKE Shimano M-525 full hydraulic disc, 6” rotor
BRAKE LEVERS Shimano M-525 full hydraulic disc
FRONT DERAILLEUR Shimano M-510 Deore, 34.9mm clamp, top pull
REAR DERAILLEUR Shimano M-750 XT, long cage, standard spring
SHIFT LEVERS Shimano M-510 Deore
CASSETTE Shimano HG-50 LX, 9-speed, 11x34t
CHAIN Shimano HG-53
CRANKSET Custom Shimano Hollowtech, Octalink XT Spline
CHAINRINGS 44Ax32Sx22S, 4 bolt 104/64mm pattern, steel chainring bolts
BOTTOM BRACKET Shimano ES-30 Octalink spline, 68mm shell, 118mm spindle. 50mm chainline.
PEDALS Shimano M-505 SPD
RIMS Mavic XM117 Disc, 26”, black
FRONT HUB Specialized disc, 32 hole, loose ball bearings, alloy Q/R
REAR HUB Shimano M-475 disc, 32 hole, loose ball bearings, alloy Q/R
SPOKES 1.8mm (15g) black stainless, brass nipples
FRONT TIRE Specialized Adrenaline 2.0, aramid bead, dual compound 60tpi
REAR TIRE Specialized Adrenaline 2.0, aramid bead, dual compound 60tpi
TUBES Specialized, schraeder valve
SADDLE Specialized BG technology, hollow Cr-Mo rails, dual density base
SEAT POST 2014 butted Alloy, black, 30.9 x 350/400mm
SEAT BINDER Alloy collar with Q/R, 34.9mm clamp I.D., black
Bild: http://www.bikx.com/shop/catalog/images/FSRXCProDisc1.jpg
Stevens F9 LITE 2005 mit Disc
Rohrmaterial: Aluminium 6000DB t-wall
Gabel: Manitou Black Super Air, Lockout, 100mm
Federbein: Manitou SPV AIR 3 Way, 90+120mm
Steuersatz: FSA Ahead Integrated Orbit Z 9, 1/8
Kurbel: Shimano Deore LX M580 Hollowtech 2, 44-32-22
Innenlager: Shimano Deore LX M580 integrated
Schaltung hinten: Shimano Deore LX M580
Schaltung vorne: Deore LX M581
Kette: Shimano HG73
Cassette: Shimano M580 11-32
Pedale: MTB Alu Dual Side
Naben hinten: Shimano Deore LX M580 (Disk: M585)
Felgen: Mavic XM117 (Disk: XM117D) 32 L
Speichen: DT Swiss Competition 2.0-1.8mm
Reifen: Continental Vapor Pro 26x2.1
Lenker: Oxygen Driver Rise 630mm
Vorbau: Oxygen Driver OS
Sattel: Oxygen Velocity
Stuetze: Oxygen Driver 350mm
Schalthebel: Shimano Deore LX STI M580 (Disk: M585)
Bremshebel: Shimano Deore LX STI M580 (Disk: M585)
Bremsen: Shimano Doere LX V M580 (Disk: LX M585)
Gewicht: 12.5 kg V, 12.8 kg Disk
Groessen: 17, 19, 21, 23
Farbe: Laguna Black
Bild: http://www.bikx.com/shop/catalog/images/F9LITE.JPG
Schon mal im vorraus Danke für jede Meinung und fast jeden Kommentar....
Re: Specialized FSR XC Pro <> Stevens F9 LITE
