Hi was darf ein 2009 EPIC FSR MARATHON CARBON noch kosten Zustand gut ( war ein Testrad ) .
Neupreis war 4800 â¬
Garantie hat es noch auf Rahmen, Dämpfer und Gabel .
# RAHMEN FACT 9m carbon front triangle, IS construction, M5 aluminum rear triangle. sealed cartridge bearing pivots, 100mm travel, replaceable derailleur hanger
# FEDERBEIN Specialized AFR remote mini , BRAIN inertia valve w/ BRAIN fade and rebound adj.
# GABEL Specialized Future Shock e100, 100mm travel, Brain Fade, external rebound adj., single sided air spring and damper, carbon 1-1/8" to 1.5" steerer
# STEUERSATZ 1-1/8" to 1.5" Threadless, Campy style upper and lower cartridge bearing
# VORBAU Specialized adjustable rise, 31.8mm clamp, 3D forged w/ CNC finish
# LENKER Specialized XC low rise 31.8mm bar, 2014 butted alloy, 6 degree up, 8 degree backsweep, 640mm wide
# LENKERGRIFFE Specialized thin lock on grip (S/M) Specialized Thick lock on grip (L/XL)
# VORDERRADBREMSE Custom Avid Ultimate SL, alloy backed organic pads, alloy caliper, magnesium lever body w/ carbon blade, SS hardware package, S/M: 160mm, L/XL: 185mm rotor
# HINTERRADBREMSE Custom Avid Ultimate SL, alloy backed organic pads, alloy caliper, magnesium lever body w/ carbon blade, SS hardware package, S/M: 140mm, L/XL: 160mm rotor
# BREMSHEBEL Custom Avid Ultimate SL Hydraulic
# UMWERFER Shimano M770 XT, DMD, top swing, dual pull
# SCHALTWERK SRA M X-0, 9-speed, mid cage
# SCHALTHEBEL SRA M X-0 carbon, trigger
# KASSETTE Shimano M770 XT, 9-speed, 11-34t
# KETTE SRA M PC -971, 9-speed w/Power Link
# KURBELSATZ Shimano FC-M770 XT, 2pc., S: 170mm, others: 175mm
# KETTENBLÃTTER 22S x 32A x 44A, 4-bolt, 104/64mm
# INNENLAGER Shimano BB-91, OS, press-in bearing
# PEDALE None
# FELGEN DT Swiss XR 4.2D, 24mm w/ eyelets, 28/32h
# VORDERRADNABE Specialized Hi Lo disc, CNC flange, sealed cartridge bearing, Oversized end caps, 9mm DT RWS, alloy QR, 28h
# HINTERRADNABE Custom DT Swiss 280S w/ Star Rachet, alloy freehub w/ DT RWS, 10mm alloy QR, 32h
# SPEICHEN DT Swiss Super Comp 2.0/1.7/1.8mm butted stainless, black, alloy nipples
# VORDERREIFEN S-Works Fast Trak LK , 26x2.0", 120 TPI , tubeless ready aramid bead, dual compound
# HINTERREIFEN S-Works Fast Trak LK , 26x2.0", 120 TPI , tubeless ready aramid bead, dual compound
# SCHLÃUCHE Specialized Ultralight 26x2.0", presta
# SATTEL Specialized Phenom SL, Ti rails, thin foam, S/M: 130mm, L/XL: 143mm
# SATTELSTÃTZE Thomson Elite Setback w/ 12 degree clamp, S/M: 367mm L/XL:410mm
# SATTELSTÃTZKLEMME 36.9mm clamp, one bolt for carbon frame/post
# PEDALE None
