[DIY] Wireless Dropper Post
Grüße. Gibt es irgendwo Dateien und Anleitungen zum Herunterladen, um dieses Projekt selbst umzusetzen?
P. MIT. Ich habe mit Hilfe eines Übersetzers geschrieben, ich kann kein Deutsch.
Yes. I used a transparent print for v2 to see whats going on inside.
Worked pretty good most of the time, but sometimes the plunger got jammed, so further optimization was necessary.
I've just finished assembling v3:
And I have also a solution if there is no opening in the seat tube for the antenna. It is basically the same PCB communicating with the actuator over a 4-wire flat flexible cable:
