Sram Kassette und Kette zusammen mit einem
Sram Kettenblat und ein XT m8100 Schaltwerk mit Shifter.
Funktioniert. Einfach das GX Schaltwerk und Shifter gegen XT ausgetauscht.
Das ist interessant und habe ich noch nie gehört.
Ich möchte ja eigentlich die komplette XT 8100er Gruppe fahren, bis auf deren Kurbel und Kettenblatt. Mir schwebt da Hope oder e*thirteen vor. Beide Hersteller haben da normal runde oder ovale boost 12x Kettenblätter im Angebot ohne explizite Hyperglide + Freigabe.
Dann bekam ich jetzt von Hope folgende Aussage:
".... our current chainrings are not compatible with the
shimano 12 speed chain, but if you use this chain with a
SRAM quicklink then all will work ok. It's fine with the 12 speed
SRAM system."
... und von Absolute Black diese:
"if you already have the chain, by switching the quick link for a
SRAM Eagle one"
"and if you don't you can use
SRAM Eagle or kmc 12 spd chain and it will work perfectly with the whole drivetrain"
"prior to the release of our hg+ chainrings I had a yt Capra with e13 crank and our chainring I switch to
Shimano XT 12 spd and replace the quick link as an advice from a colleague also working in the bike industry"
"it worked perfectly and it works fine so far never had an issue whatsoever"
"as I mentioned our ring works perfectly like that -
Shimano HG+ chain with
sram link xt cassette and rear derailleur and e13 crankset fitted with our ring "
shimano has developed a different 12 speed chain for their new chainring it has a different width between the rollers so it needs a wider narrow teeth, since this is the "small teeth" of the Narrow wide system any 12spd chainring can run the chain"
"but since the
shimano 12spd quick link it has a different size also this will not engage properly on the wide tooth of the chainring"
"I've tested it in loose dirt and mud and it worked perfectly, one of our members used
shimano drivetrain but with
SRAM Eagle chain (not just the quick link) and when in the mud he did experienced some gear issues"
"thats why my first option is to go just for the quicklink"
Ich habe erst gestern so richtig verstanden was die mir sagen wollen. Ich muss einfach nur ein
SRAM Kettenschloss anstatt das
Shimano Eigene in die Hyperglide + Kette bauen, dann steht nichts mehr im Weg ein universelles Kettenblatt von e*thirteen oder Hope mit ebensogleich favorisierter Kurbel mit der XT m8100 Gruppe zu fahren.
