- 5. November 2020
- 5
24.10.2020 - my rox 12 has started to show completely wrong values. Example: on a climb it indicated -10. On the plain he suddenly indicated -20 then returned to “0”. The “Altitude” data was also wrong.
Back home, I removed the cover and found a few drops of water (the day before it was drizzling). I dried everything.
25.10.2020, I went out on MTB, but the situation hadn't improved much.
Now, it works better. The "Altitude" data are correct but often "incline in%" does not work correctly (example: I start a constant climb and the data changes continuously)
What can I do?
What can I do?
