Sorry for the English guys, I do not speak German, but I love German bike (I have a 601 MK1 190)
Have a question. How to increase Lyrik SoloAir 170 mm travel to 180 mm?
If this was discussed before, show me please where can I read about it?
thanks
Why?Oh noooo, don't cut the Bumpers
No, travel will increase by length of the spacer (10mm) because end of travel is realized by hitting of the sliders (stanchions) on the bottom of the casting. So basically you pull out the sliders by 10mm so that they can slide down 10mm more.Thanks, but I'm not sure about the spacer.
This only increases the height of the fork (a2c), but the travel is still 170 mm.
While this modification will change the volume of the negative spring, you may get problems with the motion range of the damper unit at full extension (top out on damper side). Motion range to the bottom seems ok with the spacers (I didn't try the spacers by myself).Why?Oh noooo, don't cut the Bumpers
Will this may change the characteristics of the negative spring?
