hier mal fakten
The Travis comes in two forms, the single crown and the twin crown. In each 'form' their are two damping systems, a new TPC+ which sits in a full open bath (like Marzocchi have always done and what makes them last a long time and feels sooo plush) rather than have the oil in a sealed cartridge and the new Intrinsic damping.
The Intrinsic is based around the SPV system but it removes the platform and just uses it's bottom out resistance properties. It's speed sensitive and supposedly offers incredible small bump performance.
Both the TPC+ and the Intrinsic only have compression and rebound adjustment.
There's also two other models but i think they're OEM only, the Travis Faction Single and the Travis Flare Triple both 203mm travel, heavier, with steel stanchions, only semi bath lubrication and made in Taiwan rather than the US.
Weights from the specs i have are -
Travis Single 150 (1.125" steerer) - 5.6lbs / 2539g
Travis Single 180 - 5.8lbs / 2650g
Travis Single 203 - 5.9lbs / 2676g
Travis Single Intrinsic 180 - 5.8lbs / 2650g
Travis Single Intrinsic 203 - 5.9lbs / 2676g
Travis Triple 180 - 7.8lbs / 3541g
Travis Triple 203 - 7.9lbs / 3583g
Travis Triple Intrinsic 180 - 7.1lbs / 3220g
Travis Triple Intrinsic 203 - 7.2lbs / 3256g
Travis Single 150 Axle to Crown Height -542mm
Travis Single 180 Axle to Crown Height - 572mm
Travis Single 203 Axle to Crown Height - 595mm
Travis Triple 180 Axle to Crown Height - 562mm
Travis Triple 203 Ride Height - 585mm
Recommended max tyre width - 2.75" / 70mm
There's also a rear shock called the Revox ISX which is a super high end DH/FR shock (at a guess the price is around £575-600GBP which is calculated from the OEM price). It uses the same speed sensitive Intrinsic damping system which gives the same adjustments as the current Swinger 6 way shock but it also lists three stage 'no tools' (Manitou's new buzz phrase to say that it doesn't need tools to adjust any part of it (apart from air pressure, obviously) SPV adjustment... Manitou don't make it clear what that is. It's quite possible it won't be available for 2006, it might disappear like the Evolver (DH air shock) did even though it was supposedly available or it may even be released!
http://www.ridemonkey.com/forums/showthread.php?t=116864&page=4&pp=15
