RCZ-Glaskugel: Wartezimmer, Spekulationen, Austausch
Re: RCZ-Glaskugel: Wartezimmer, Spekulationen, Austausch
Soweit ich weiß müsste die auch nochmal 150-200Gr schwerer sein.
Kann mir übrigens mal jemand das Produktmanagement dahinter erklären? Dass es eine 36er eBike mit verstärktem Chassis gab, solange die 38 gefehlt hat, verstehe ich. Aber die 38 wurde doch auch als ästhetischer Ausgleich zum eBike gefeiert. Wieso baut man denn dann immer noch eine 36er im Sonderformat und extra schwer?
Oder labere ich hier Stuss und es ist auch bei der 36er nur noch der Tune?
As far as I know it should be another 150-200g heavier.
By the way, can someone please explain the product management behind this to me? I understand that there was a 36-inch eBike with a reinforced chassis while the 38-inch was missing. But the 38-inch was also celebrated as an aesthetic counterbalance to the eBike. So why are they still building a 36-inch bike in a special format and extra heavy?
Or am I talking nonsense and it's just the tune on the 36 too?
You are right. There are 2 different 36s for e-bikes. E-optimised and E-tuned. E-tuned is just a different damper tune (and 68mm crown) while e-optimized is with enforced chassis meaning it has thicker sliders, Fox34 air piston and so on - and that is as heavy as 38.
But it doesn't mean that damper is from 34 (length is different). GripX2 damper from regular 36 will fit into e-optimized from diameter vice.
And I don't actually know for fact if air cap even is having similar threads of 34 or 36 (or if there even is difference in thread size). But sliders are thcker so that air piston is from 34 (or course again - piston shaft has sizes from 36 (since 34 stops to 150mm while 36 goes to 170).
Die 34er Factory ist aus 2025 mit Grip SL leider mit 51mm Offset
2025 FACTORY 34 FLOAT 29 100​
2025, 34, K, FLOAT SC, 29in, F-S SC, 100, Grip SL, Remote-Adj, Psh-Lk, (10pm CP), Matte Blk, Neutral/Matte Blk Logo, Kabolt 110, BLK, 1.5 T, 51mm Rake, OE
Gerade eine Versandbestätigung bekommen für:
MAVIC Wheelset CROSSMAX XLS 29" Disc CL (15x110mm/12x148mm) Microspline Black
Bestellt am 01.04. ....was ist los bei RCZ? Die schreiben 20 Working Days, das sind jetzt nur knapp 6 WD, war wohl doch "in Stock" 🤔
Ist laut Datenbank eine Grip X2
2025 FACTORY E-OPTIMIZED 36 FLOAT 29 160
2025, 36, K, FLOAT, 29in, F-S E-Optimized, 160, Grip X2, HSC, LSC, HSR, LSR, Shiny Blk, Neutral/Gloss Blk Logo, 15QRx110, 1.5 T, 68HT, 44mm Rake, OE
gibts eine Fox Datenbank um über die Artikelnummer Infos zur Gabel zu bekommen.
Kannste du mir die Datenbank bitte verlinken?
