hab ne Frage zu meinem neuen Bike Specialized Stumpjumper Ht...
Nachdem ich mir das gekauft hatte wurde mir gesagt das ich da keinen guten Fang gemacht habe aber ich bin anderer Meinung.Ich hoffe ihr könnt mir weiter helfen.
Die komponenten:
RAHMEN M5 alloy hardtail, fully manipulated DT, TT, SS, CS, ST w/ shared tube Mono-stay seatstays, new larger diameter/stiffer ORE DT/TT, disc mount, replaceable derailleur hanger
FEDERBEIN N/A
GABEL Fox F90 RL, 90mm travel, air spring, rebound/compression adjust w/ lock out, alloy steerer
STEUERSATZ 1 1/8" threadless, alloy cups w/ 10mm insertion, sealed cartridge bearing
VORBAU Specialized adjustable rise, 31.8mm clamp, 3D forged w/CNC finish
LENKER Specialized XC flat 31.8mm bar, 2014 butted alloy, 6 degree backsweep, 600mm wide
LENKERBAND/GRIFFE Specialized thin lock on grip, dual density
VORDERRADBREMSE Avid SD-5R, cantilevers, cartridge pads, lightweight compressionless housing
HINTERRADBREMSE Avid SD-5R, cantilevers, cartridge pads, lightweight compressionless housing
BREMSHEBEL Avid FR-5
UMWERFER Shimano M581 LX, 34.9mm clamp, bottom swing, dual pull
SCHALTWERK SRAM X-9, 9-speed, mid cage
SCHALTHEBEL SRAM X-7, aluminum 9-speed trigger
CASSETTE FREEWHEEL Shimano HG-50, 9-speed, 11-34t
KETTE SRAM PC-971 w/ Power Link
KURBELSATZ Shimano A/A/S 2pc custom
KETTENBLÄTTER 22S/32A/44A, 4 bolt 104/64mm
BOTTOM BRACKET Shimano M542, 2pc custom for Specialized
PEDALEN Crank Brothers Smarty custom for Specialized
FELGEN Mavic X317, 26", black w/ eyelets, 28/32h
VORDERRADNABE Specialized Hi Lo disc, 28h CNC flange and disc mount, sealed cartridge bearing, 9mm DT RWS alloy QR
HINTERRADNABE Shimano custom M525SL hub for Specialized, 32h, alloy QR
SPEICHEN DT Swiss 1.8mm stainless, alloy nipples
VORDERREIFEN Specialized Fast Trak Control LK, 26x2.0", 60TPI, tubeless ready aramid bead, dual compound
HINTERREIFEN Specialized Fast Trak Control LK, 26x2.0", 60TPI, tubeless ready aramid bead, dual compound
SCHLÄUCHE Specialized Ultralite, .6mm, presta
SATTEL Specialized XC MTB, hollow Cr-Mo rails, SL foam
SATTELSTÜTZE 2014 butted alloy, single bolt setback, 30.9 x 350/400mm
SATTELSTÜTZKLEMME Alloy single bolt, 34.9mm clamp ID
ANMERKUNGEN Protective clear coat, derailleur hanger, reflectors, owners manual
Und bezahlt habe ich 1200 anstatt erst 1400(preisnachlass wegen eines Minikratzers...=))
Hoffe könnt mir weiterhelfen.
Die komponenten:
FEDERBEIN N/A
