FRAME
FSR technology, M4 Manipulated Alloy frame with TransForm Monocoque TT, sealed cartridge bearings, disc compatible, 100mm travel, replaceable derailleur hanger, two sets of water bottle bosses
REAR SHOCK
Fox Float Triad. Custom on-the-fly three position switch 1) Lockout, 2) Open, 3) ProPedal pedal assisting damping. External rebound adjust, twin sleeve design for increased volume. 6.5x1.5
FORK
Fox Float RLC, 100mm travel, rebound adjust, compression adjust, w/ lockout & threshold adjust, alloy steerer
HEADSET
1 1/8 threadless, 3x sealed, black alloy cups, cartridge bearings, ultralight alloy top cap and bolt
STEM
3-D forged CNC machined, 4 bolt, 6 degree rise, black
HANDLEBARS
Specialized XC Low Rise bar, 2014 butted alloy, 6 degree upsweep, 8 degree backsweep, 640mm width
TAPE / GRIPS
Specialized MTB grip, black, double density Kraton
FRONT BRAKE
Shimano M-765 XT hydraulic disc, metallic brake pads, 6 XT Rotor
REAR BRAKE
BRAKE LEVERS
Shimano M-765 XT hydraulic disc w/ integrated shifters
FRONT DERAILLEUR
Shimano M-760 XT, 34.9mm clamp, bottom pull
REAR DERAILLEUR
Shimano M-952 XTR, long cage, standard spring
SHIFT LEVERS
Shimano M-760 XT, STI integrated shifter/lever combo
CASSETTE
Shimano M-760 XT, 9-speed, 11x34t
CHAIN
Shimano HG-73
CRANKSET
Shimano M-760 XT Hollow Tech II, 2-piece crank/BB
CHAINRINGS
Shimano 44Ax32Ax22A, 4mm thick outer, 4 bolt 104/64mm, alloy chainring bolts
BOTTOM BRACKET
Shimano M-760 XT, integrated with crank
PEDALS
Shimano 520 SPD
RIMS
Mavic XC717 disc, 26, black, welded seam, eyelets
FRONT HUB
Specialized Stout disc, 32 hole, sealed cartridge bearings, 9mm Skraxle
REAR HUB
Shimano M-756 XT, 32 hole, alloy Q/R
SPOKES
DT Swiss Super Comp 2.0/1.7/1.8mm butted SS, blk, alloy nipples, L264/R261mm front, L262/R262mm rear
FRONT TIRE
Specialized Roll-X Pro 2.0, aramid bead, 120tpi
REAR TIRE
TUBES
Specialized Ultralight, presta valve
SADDLE
Specialized Body Geometry technology, microfiber cover, dual density base, titanium rails
SEAT POST
2014 butted alloy, black, 30.9 x 350/400mm
SEAT BINDER
Alloy collar with Q/R, 34.9mm clamp I.D., black
lgc.
