Triptube
Bergkaninchen !
Na jut, war ja nur ein Vorschlag !
Kenne mich damit nicht so aus, was den Zoll anbetrifft.
Happy trails !
Steve
Happy trails !
Steve
Habe die TruckerCo nun etwa ein Monat in Benutzung. Bei Abdichten ging alles schnell und glatt wie mit FRM bzw. Stans. Pannen hatte ich keine. Ich mach mal am Sonntag die Reifenflanke auf und schaue mal nach, ob die Milch eintrocknet wie FRM bzw. diese Gebilde bildet wie Stans.Wie lange hält sich das Zeug bei Dir?
Bei dem Preis könnte es echt eine Alternative werden.
habe ich dann noch einen Test mit einer Heftzwecke gemacht. Da ich bisher keine Platten hatte, wollte ich auch sichergehen, dass im Falle einer Panne die Milch wirkt.Well I bit the bullet and decided to try this stuff out and bought a liter of this sealant. It went in pretty smoothly and it was nice that it came with a syringe to help insert the sealant. Now the bad part...I rode
my bike this fall around the local trail and everything was going fine
till it started getting dark fast, this was just before daylight savings time kicked it. I stopped for a bit, then started up on the bike and pssstt... I heard that dreadful sound. I knew right away I got a puncture in the front tire and this milky substance started spilling out. I was hoping it would stop so I just kept riding. After about 100 yards I checked again and it was still leaking and my tire was getting flatter.
It was getting darker and I still had a ways to go. Finally after about another 500 yards the tire was just too flat to continue so I pumped more air into in. Eventually I made it home but I still had to pump air into it every now and then. The sealant just seems to slow the leak but didn't quite plug it up. Now the bike sits in the garage and the air finally leaked all out. Not to happy about this product. Its too liquidy to be a used for punctures and maybe its just that. Its just a sealer for tubless tires and does a good job at that but not a product for sealing punctures. I will probably mix it with the "green" stuff and use it again since the "green" stuff has tiny bits of particles that could help block punctures or maybe mix it with some glitter.
Muss leider meine letzte Aussage korrigieren. BCC wird auch mit RevoSeal nicht dicht!
In der Mischung scheint ein hoher Silika-Anteil zu sein. Auch eine Reparatur mit Tubeless-Flickzeug verlief nahezu erfolglos. Der BCC lässt sich nicht mehr vulkanisieren....
Die RQ gingen normalerweise erst in eine Woche platt.
