hier noch mal die ausstattung:
High Octane
Rahmen: Scott 7005 Aluminium Carbon Sitzdom 180-240mm Travel
Gabel: Manitou Stance Kingping mit 170 mm Federweg
Dämpfer: Manitou Metal RP Dämpfer
Schaltwerk:
Shimano XT 27 Speed
Umwerfer:
Shimano Deore
Schalthebel:
Shimano Deore
Bremshebel: Hayes HFX-9 HD Disc
Bremse: Hayes HFX-9 HD Disc 205mm
Kurbel: RaceFace Evolve DH 22-32
Lenker: Scott Pilot FR Pro 680mm
Vorbau: Scott Pilot FR
Pedale: LU-987 SCT BMX Typ
Sattelstütze: Scott Comp
Sattel: Scott DH SCT-14
Naben: KT-DH 20mm Axle vorne
Shimano M-525 hinten
Cassette:
Shimano Deore 11-32T
Speichen: DT black
Felgen: Scott Alex BH
Reifen:
Maxxis Minion DH 26x2.5
Farbe: black
Gewicht: ca. 19,6 kg
BigHit
Frame: BigHit FSR, 6061 ORE TT/DT, full cartridge bearing
Shock: Fox Vanilla R coil, 8.75x2.5", 190mm travel
Fork: Marzocchi Drop-Off Triple, 170mm travel, 20mm thru axle
Stem: Truvativ Hussefelt, forged/CNC, 5 Ë x 40mm, OS clamp
Brakes:
Avid Juicy 5, hydraulic disc, 8" polygon rotor
Rear derailleur:
SRAM X-9, micro cage
Shifters:
SRAM X-7 Trigger
Cranks / guide: Truvativ Hussefelt, 170mm with Truvativ chain guide
BB: Truvativ Howitzer XR, OS sealed/cartridge bearing, 73mm
Pedals: Alloy platform, 3mm pressed pins, 9/16" Cr-Mo axle
Rims: Sun Single Track SL-1, 36 hole, 26" F/R,
Hubs: Specialized disc, 36 hole, 20mm thru axle, 36 hole bolt on axle, 135mm spacing
Tires: Specialized Chunder 26" x 2.3", 60TPI, 2 ply
Seatpost: Titec Scoper telescopic, 30.9, non-offset head
