is dieses bike gut??
5. November 2005
Innsbruck
was sagt ihr zum neuen Specialized Big Hit FSR II 06?? Also mir gefällt es zimlich gut... ein problem habe ich aber: ich habe 3 leute gefragt wegen der größe des bikes ( ich bin 177cm ) welche größe sollte ich nehmen??
thx
nIcCe gReEz michl
FRAME All new BigHit FSR, 6061 ORE TT/DT, full cartridge bearing, ISCG mount, asymetrical rear triangle, 26" F/R wheel, adjustable geometry
REAR SHOCK Fox Vanilla R coil, 8.75x2.5", 190mm travel
FORK Marzocchi Drop-Off Triple, 170mm travel, air assist, rebound adjustment, double clamp, 20mm thru axle
HEADSET 1 1/8" threadless, OS Cro-Mo cups
STEM Truvativ Hussefelt, forged/CNC stem, 5 degree x 40mm, 31.8 clamp, black
HANDLEBARS Specialized Demo rise bar, 6061 alloy, 31.8mm, 6 degree upsweep, 9 degree backsweep
GRIPS Specialized MTB grip, natural/black
FRONT BRAKE Avid Juicy 5, hydraulic disc brake 8" Polygon rotor
REAR BRAKE Avid Juicy 5, hydraulic disc with 8" Polygon rotor
BRAKE LEVERS Avid Juicy 5
FRONT DERAILLEUR None
REAR DERAILLEUR SRAM X-9, micro cage
SHIFT LEVERS SRAM X-7 Trigger, 9-speed
CASSETTE Shimano HG50, 9-speed, 11-34t
CHAIN SRAM PC-971 with Power Link
CRANKSET Truvativ Hussefelt, 170mm with Truvativ chain guide
CHAINRINGS 34T, 4 bolt, compact 104mm pattern
BOTTOM BRACKET Truvativ Howitzer XR, oversize sealed outboard cartridge bearing, 73mm shell
PEDALS Alloy platform, 3mm pressed pins, 9/16" Cr-Mo axle
RIMS Sun Single Track SL-1, 36 hole, 26" F/R, schraeder valve
FRONT HUB Specialized disc, 36 hole, 20mm thru axle
REAR HUB Specialized disc, 36 hole, bolt on axle, 135mm spacing
SPOKES 2.0mm (14g) stainless, black, brass nipples
FRONT TIRE Specialized Chunder 26x2.3" 60TPI, 2 ply, soft compound
REAR TIRE Specialized Chunder 26x2.3" 60TPI, 2 ply, soft compound
TUBES Specialized 26x2.4" schraeder valve
SADDLE Specialized freeride, 8mm steel rails, with X-Brace
SEAT POST Alloy micro adjust, 30.9
SEAT BINDER 7050 hard annodized alloy collar with QR, 34.9mm clamp ID, black
NOTES Chain stay/seat stay protector, derailleur protector, reflectors, owners manual
