Sind im Gesamtgewicht dabei, habe das komplette Rad gewogen und nicht nur die Einzelteile addiert.
Füge sie noch hinzu, extra für Dich
ja, kann man gerade so durchgehen lassen
fäääärdsch (erstmal)
The position in at the bottom gives you 197 mm travel at the rearwheel. The position at the top gives you 217 mm. The positions at the front are for diffent head angels and also bb heights...
Cannot tell you anything regarding your weight and the spring, but you might use two different spring rates based on the chosen travel. Just give it a try!
I'm using a 350 spring rate for 197 mm and a 400 spring rate with 217 mm in my DHX 4.0. My weight is about 70 kg with equipment...
Do you alreday have a spring mounted in your shock?
