Maxflex3 UI wechseln
9. Oktober 2008
219
Trebur
Hallo
Ich blick jetzt gar nix mehr. :mad:
Hab jetzt endlich meine MC-E Funzel mit Maxflex3 soweit zusammen und komme mit der Anleitung von Taskled nicht klar.:heul:
Ich war mir sicher irgendwo gelesen zu haben wie man das User Interface wechseln kann.......
nur ich find´s nicht mehr! :(
Ich möchte von UIP in UIB2 wechseln!!!!!
Könnte mir bitte jemand einen Tip geben wie ich das anstellen muß???
Danke schon mal :daumen:
Gruß Thomas
Hallo
Gruß Thomas
hallo
versuchs mal hiermit.
If you are in UIF/UIP mode, then start with the light on, or turn the light on and wait at least 1
second. Click 3 times quickly (the LED will flash off, on, off) and follow that with a press until the
LED flashes. So the sequence from the light being on is simply click-click-click-press. The press
must come directly after the three clicks, or the circuit will enter lockout mode with an indication of
three bright flashes. When you have entered the Menu successfully, the LED will be steady dim.
Note: While in the Menu system, voltage sensing and temperature sensing is disabled, again to
enable access even if an over temperature or under voltage condition exists.
Click the switch from 0 to 13 times (the LED will flash a response for each click, do NOT try to beat
the flash) to select one of the Menu options to change as listed below. To exit the Menu system
instead of choosing an option, press the switch before clicking (Sec 8.0). The LED will flash 2 times
and then the light will turn off. To re-enter the Menu system you will need to perform the proper
sequence as described above.
If any errors occur in selecting a Menu option (e.g. clicking more than 13 times or making an invalid
selection), the LED will flash quickly 5 times to indicate an error and the user will be returned to the
top of the Menu system as if it had just been entered.
If at any time you lose track or get confused about where you are in the Menu system, you can
always remove power and only the settings that have been altered (if any) will have been written to
the EEPROM.
After clicking from 0 to 13 times to select the Menu entry, press the switch to choose that menu
option.
8.13 Thirteen clicks – Select UIB2, UIB2Q or UIF/UIP Base Mode
This menu allows selection either of UIB2, UIB2Q or UIF/UIP base modes. The structure of the
firmware is such that there are two totally separate operating environments due to the very different
needs of UIB2/UIB2Q versus UIF/UIP.
Initially the LED will be dim to indicate that UIB2 base mode will be enabled (i.e. if you don’t click,
UIB2 Base Mode will be selected). A click will brighten the LED to indicate UIB2Q Base mode will be
enabled and a further click will brighten the LED again to indicate that UIF/UIP Base Mode will be
enabled. Each click will cycle through the next base mode. The sequence is:
• 0 click (dim) → UIB2 Base Mode
• 1 click (brighter) → UIB2Q Base Mode
• 2 click (brighter) → UIF/UIP Base Mode - default
If you select the UIF/UIP base mode, you then need to choose between UIF or UIP using Menu 3
(Sec 8.3).
When you are satisfied with the choice, press to save the setting. The LED will flash twice and go off
to indicate that the selection has been made. The light will remain off until turned back on by the
user.
ist ein auszug aus der Pdf:Datei des Maxflex.
Damit muss es funktionieren.
viel Glück......:daumen:
Gruß Albrecht
Oh Mann
Auf der letzten Seite war´s
Mann,Mann,Mann :rolleyes: Danke Dir! :daumen:
Nochmal eine Frage:Hab ich das richtig verstanden,daß,wenn ich aus UIF/UIP aus ins Menu gehe dann 13 mal klicken muß um von UIF/UIP in UIB2 zu wechseln?
Oh Mann
hallo
ja 13 mal klicken, dann passt es.
denk dran, wenn du auf UIB2 umgestellt hast musst du 2 Mal DRÜCKEN.
einmal um UIB2 Auswahl zu bestätigen, und einmal um den Programmiermode zu verlassen.
Gruß Albrecht
