Radon Slide Trail 29"
Has anyone tried a Megneg on their Slide/Skeen? I'm wondering if it would fit, from what I understand it's as big as some coils.
So if anyone is wondering, a Megneg fits... Just. The shock rotates forward as the suspension goes through it's travel, so you do gain a bunch of clearance, but i'm still not comfortable running it like this.
Hi.
Kennt jemand die Abmessungen der Lager und kann mir im besten Fall einen Hersteller robuster Ersatzlager nennen?
Auch für das Innenlager (orig. SRAM Boost) würde mich eine robustere Alternative interessieren.
Danke für eure Antworten.
Viele Grüße,
Mo
I was just doing some maintenance and cleaning and noticed that the bearing at the drive side chainstay pivot point is loose in the frame. I can literally pop it in and out with my fingers. Even when the bolt is tightened the chainstay can still shift a bit, since the bearing isn't supported from both sides like most other bearings on the frame, and it's only held in by the press fit (which isn't a press fit anymore). Wrote Radon, we'll see what they say, i'm just curious if anyone had the same issue. I check my pivot bolts regularly, these never even came close to loosening, probably because there is such minimal rotation at this pivot.
I had the same problem. The bearing was just pressed in and popped out after a parking lot bunny hop. This caused the rear triangle to disintegrate. Quite dangerous if this happens on a trail.
The Radon support said this was changed on later models and sent me a new rear triangle together with the Horst link set for the left side.
"Guten Morgen,
bitte entschuldige die entstandene Problematik.
Dieses Problem lässt sich relativ leicht beheben.
Benötigt wird auf beiden Seiten das Horst-Link Set für links. So wird es jetzt auch serienmäßig ausgeliefert.
Sollen wir den Umbau durchführen, oder sollen wir dir ein Set zukommen lassen?
Sind sonst noch Teile beschädigt? Sollte das neue Set nicht korrekt passen, würden wir die Sitzstrebe natürlich mit austauschen. "
The attached drawing was sent to me by Radon illustrating how the horst link should be installed.
Thanks, familiar with how everything goes together, unfortunately that's not the issue.
Contacted Radon, after a week went by I sent them another email. They got back to me after the second email saying they will ask the manufacturer for replacement parts, but said that it might take a few days to receive an answer. That was a week ago, no reply yet.
This pivot point is an "interesting" design for sure...
Servus Leute ich liebäugele mit dem Slide Trail 8.0, bin mir bei der Größe unschlüssig.
Ich bin 183 Groß und meine SL ist mit 81 recht kurz. Ich Tendiere ja eher zum 20er wobei ich da aufgund der SL unschlüssig bin, hab ich was vergessen zu bedenken ?
Fahre auch noch ein anders Bike das von Reach und Stack her ähnlich ist.
Eventuell hat ja jemand ähnliche Werte...
Grüß aus Oberschwaben
20" for sure, your limiting factor will be the seat tube length. I'm 185cm with a ~92cm inseam so that's not relevant, but my buddy rides a 20" Slide, he is 183cm with a 82cm inseam and the stock 130mm dropper is almost completely slammed in the frame.
I wouldn't go smaller, in terms of length the Slide/Skeen is a bit on the short side as is.
BTW Radon sent me new seatstays due to the loose bearing. It took ~2-2.5 months but at least I got something. I'd urge everyone to use Loctite retaining compound when installing bearings at the next service. Such a stupid design.
Hallo zusammen, ich konnte im IBC Markt einen gebrauchten Slide Trail Rahmen aus 2020 ergattern leider ohne Steckachse. Weiß hier jemand welche man hier benötigt, ist ja eine M12 mit Gewinde 1,0 ist das dann eine Syntace X12 Boost. Vorab schon mal Danke
Hallo. Ich habe den 21-er, da ist eine Newmen 12x148 mit 12x1 eingebaut. Gruß und viel Spaß mit dem Bike.
hat jemand am slide trail 8 von 2022 die nx kasette durch eine gx 10/52 ersetzt? weiß zufällig jemand ob der freilauf passt oder ob man diesen auf den SUNringlé Düroc 35 Expert felgen auch ersetzen muss
Der größte Gang am NX hat 11 Zähne, GX und drüber haben 10 Zähne. Insofern brauchst du einen anderen Freilauf. Die GX-Kassette passt leider nicht auf den NX-Freilauf.
Ich habe gestern den Slide Trail 8 AL in Größe M erhalten. Ich bin 1,77mtr SL 83 cm.
Laut der Größentabelle von Radon liege ich zwischen Größe M/L.
Das Komische ist, dass die Variostütze (150 mm) in Größe M viel zu hoch für mich ist. Wenn die Sattelstütze so weit wie möglich im Rahmen steckt, komme ich mit den Zehen gerade noch auf den Boden. Hat noch jemand diese Erfahrung gemacht?
Und wäre es wegen des gekröpften Sitzrohrs anders in Größe L (auch mit 150mm Variostütze)?
Danke im Voraus für die hilfe (Entschuldige wenn mein Deutsch nicht optimal ist, bin Niederländer in Berlin).
Wie sieht bei denen die das Rad schon länger haben der Tretlagerbereich aus - schützen die Züge da vor Steinschlag?
Für mich sieht es komisch aus, dass der Rahmenschutz da so früh endet.
Innenbeinlänge * 0,885 = Sitzhöhe von Tretlagermitte bis Satteloberkante.
