RCZ Angebote [Achtung, unsicherer Shop]
Re: RCZ Angebote [Achtung, unsicherer Shop]
Can someone tell me why to choose this way and how it works please?
Prices in the EU deviate because of different VAT tax numbers, but also, depending on the logisticts contract, shiping prices also vary quite a bit. The we have something called price discrimination, different countries in the eu get different pries from the same shop. The latter is illegal in the EU as far as i know.
I also checked the prices with a Rockshoc Lyrik as an example (228840701) - it's interesting, that there is one with a regular price of 799 € for pretty much all (i did not check every last county), but if you buy from the german translatet website its around 820 €. But since the prices change as soon as you apply a code, only the flying spaghetti monster knows whats going on🤷‍♂️
Open a product:
https://www.rczbikeshop.com/default/aerozine-seat-clamp-rapide-31-8mm-red-aesrrap7.htmlRemove 'default' and write 'finland' in the link.
Try 'it' instead for italy.
To order in your country you need to be logged in.
Price Varies for each country. Take the country with the lowest price. It is Not always finland.
Alright, thanks for the explanation! That's interesting. I have tried it following the steps you told me, as you can see in the pictures.
The point is that if I set Finland as country and I add the item in the cart (which actually has the lowest prices for the item you sent the link), then once filling the shipping options the only shipping country that the system let me choose is Finland.
I guess I'm doing something wrong and there must be a way to choose another shipping country (Germany) while being in the "Finland version rcz webpage", right? thanks
As said above, the system doesn't let me choose a different shipping country than the one set for viewing the webpage..
Just go to checkout without chosing a shipping Adress. In the next steps you login. Then you are able to chose your saved Adress.
hab schon ewig nix mehr bei rcz bestellt ..jetzt wäre ich fast bei dem eagle axs schaltwerk schwach geworden muss aber sehen das eine lieferung nach deutschland nicht angeboten wird- wie bestellt ihr denn alle im moment dort?
mfg ride on
