summer is well on its way, and usually meanâs stuffs going down, with that in mind lead me to the purchase of a motion capturing camera.
if you are planing on whipping out your own, hereâs a DIY steady cam handle for you to make..
off the back of the idea of the T1 camera holder i bought my mate a few years back for Christmas that featured a grip on it, subsequently made me think of using bar tubing, and then if maybe there was a way of using some of the structure of a existing welded bar.
i have never seen any 1 else do it, so i was pretty stoked when it came out so well.
from the pictures its relatively self explanatory.
but if you need to be spoon feed it, here it isâ¦
-get some bent, unfashionable bars
-make sure that the camera your using will fit in terms of height (between crossbar and stem clamp area
-get an angle grinder or hack saw and get medieval on that shit!
-then repeatedly clamp cross bar tube in vice to achieve a flat sided oval shape
-mark out 2 bolt holes (1 for small battery use other for larger) and drill
- find bolt and grips and bar end..
-GO FILM
so solls dsann aussehen
-GO FILM
