Kennt jemand das Zeug hier ?
Joeâs No Flats Eco Sealant review | £9.99
While the name has similarities with other sealants, Joeâs Eco is fine if youâve got a latex allergy, and thereâs nothing in it that will kill fish.
Granular/gritty âmicro particlesâ help block holes faster and more permanently, and it will also block bigger holes than a runnier sealant. All of this is really noticeable in use.
It seals tubeless-ready setups quickly and has bridged bubbling gaps on tyre/rim pairings that werenât sealing with lighter Latex-based liquids. Weâve had no issues with thorn or cut punctures either, although comparing that to other sealants is always a slightly random process.
At under £10 for 240ml itâs definitely good value, though, and the bottle and tube makes getting the sealant in there easy whether the valve stem is removable or not. The only downsides are more lumps inside the tyre after a while, so you need to clean it out and refresh it a bit more regularly.
This article was originally published in Mountain Biking UK magazine, available on Apple Newsstand and Zinio.
"Quick to use and effective, friendly to wildlife and latex allergy sufferers, but lumpy after a while"
http://www.bikeradar.com/gear/categ...uct/review-joes-no-flats-eco-sealant-12-46628
Happy trails !
Steve
