Hat sich erledigt, doch noch was gefunden !!
Falls noch jemand Interesse an den Größen hat, hier die Info von Pinkbike:
Earlier 7POINTs use:
2X 6902 2RS MAX (lower main pivot)
2X 6000 2RS MAX (upper rocker frame pivot)
4X 608 2RS MAX (chainstay and seatstay pivots)
Later 7POINTs and all 6POINTS use
4X 6902 2RS MAX-E (lower main pivot and chainstay pivot)
2X 6000 2RS MAX-E (upper rocker frame pivot)
2X 608 2RS MAX-E (seatstay pivots)
The E stands for Extended inner race, these were custom bearings that I sourced from Enduro. You can still buy them directly from Enduro as a kit I believe. Stock non extended bearings will work fine on the later frames but you will need a 3mm wide spacer to go between the bearing and frame/link if you don't' have the extended race bearing available.
It makes me happy to see so many IH's still alive and getting abused. That 7POINT is one of my favorite bikes of all time.
hope this helps,
Dave
Marco
hope this helps,
Dave
Marco
und meins springt und schluckt alles...
