Ghost Nirvana Tour
ATM I ride Cube AIM XL size and it seems just a little bit too large. Geometry difference between Cube and Nirvana is noticable
You need to include stem length and handle bar geometry in your consideration to get to the so called rider compartment, the actual length from seat to grips. You could adjust that by changing to a different length stem for example. Just to mention that frame geometry alone is not enough to figure out bike fit.
Will the L size feel to small for me and be a problem?
The Nirvana frame in L is considerably longer than the Cube in XL but the stem will be shorter. So 'rider compartment' won't be that different. Even if it is, that can easily be adjusted. Probably even without changing parts.
Some people might want to have an even longer bike, the Nirvana has a relatively upright and therefore relaxed rider position, but I guess that's not you.
Long story short: I think L is fine for you.
McDerec, thanks! I did put shorter stem on my Cube, and wider bar, so it did help a bit. I was just a bit worried seing some of you with similar height / SL opting for XL size, yet super-fit chart clearly recommends L. I will opt for L, hoping it would be more playful on trails, and on longer rides use my Cube :)
Glaubt ihr L wäre möglich? Ansonsten bleibe ich wohl eher beim Merida. Vielen Dank für eure Tips
L wäre bei Deinen Maßen nötig, und möglich.
Ich bin 180/85 und hab vor dem Kauf alle drei Größe getestet. M war mir def. zu kurz, da dein Oberkörper länger ist als meiner, geht M für dich garnicht...vergiss die Größenempfehlungen von Ghost...so ein Schmarn...die sind schon mit ausgeglichenen Proportionen mit Vorsicht zu genießen.
Mit dem Dropper musst halt aufpassen, bei Deiner SL passen da nach meiner Berechnung im Schnitt 145mm rein. Also entweder ein 150mm der flach baut, oder jeder 125mm.
If you want to use a dropper post with more travel than 100mm (mostly recommended for trail riding) your legs are to short for XL or - if it sounds better to you - the seat tube is to long ;)
So i think L is fine but you should use a longer stem (60 or 70mm).
Das XL hat eine STL von 49cm, also 2,5cm mehr als das L. Ich hab mit SL 85cm einen 150mm Dropper drin den ich noch 2,5cm ausgezogen habe. Sprich bei meiner SL würde der Dropper auch im XL passen.
@Elyseus hat wohl SL 86cm, da passt das erst recht mit dem 150mm Dropper, und hat sogar noch 1cm Luft.
Oder wie der Engländer sagt: "XL fits perfectly" :daumen:
Bin von meinem HT mit 470mm Sitzrohr ausgegangen, da passt eine OneUp in 180mm bei 84cm Innenbeinlänge gerade so.
Also habe ich mich wohl vertan ;)
@Elyseus Sorry, i was wrong. What @sebhunter says.
The XL has an STL of 49cm, so 2.5cm more than the L. I have a 150mm dropper in it with the SL 85cm which I took off 2.5cm. In other words, with my SL, the dropper would also fit in the XL.
[USER = 565363] @Elyseus [/ USER] probably has SL 86cm, so that fits with the 150mm dropper, and even has 1cm of air.
Or as the English say: "XL fits perfectly" :thumb:
Now, I am confused again😜Ghost says "XL would be too big for you", you say XL will fit perfectly.o_O
From what I understood, reading this thread, is that dropper post size depends on how long the seat post is. Ok, that I do understand. Although, I must state that I would be ok with 120mm dropper.
So, regardless of the dropper post, would the L size be acceptable with stock stem (45mm)? Because, right now, my Cube has 425mm reach, compared to Nirvana's 457mm in L size. And stack size on Cube is also 14mm smaller. So my logic is: if my Cube in XL seems a bit too large, just a bit, and Nirvana's geometry is larger in reach and stack (only seat post being 5cm shorter), I'm guessing the L Nirvana would be perfect, just like Ghost chart suggests.
Yet, you @sebhunter say that XL would fit perfectly, and I don't have any reason not to believe you. But why would then Ghost put that chart? Did they missed the recommendation that much?
Hi, ich kann Dein Englisch zwar fließend lesen, schreiben ist aber zu anstrengend, daher hoffe ich Du kannst dir das übersetzen. ;)
Die Grössenempfehlungen der Hersteller sind allgemein mit Vorsicht zu geniessen. Ich zum Beispiel bin 180cm mit SL 85cm. Mir würde Ghost Grösse M empfehlen, hab ich auch getestet und ist zu kurz.
Daher habe ich es in L genommen.
Natürlich sind das alles rein persönliche Einschätzungen und Empfehlungen, aber bei mir sieht das so aus...sieht das zu gross aus?
Du bist 5-6 cm grösser als ich, und hast einen längeren Oberkörper. Wie würdest Du aussehen wenn du auf meinem L sitzt? Das XL ist in alle Richtungen 3cm größer, wie wäre das dann?
Zu deinem Cube: Das Cube hat wahrscheinlich mindesten einen 90mm Vorbau (Stem) daraus ergibt sich dann bei 425mm Reach ein virtueller Reach von 515mm. Das Nirvana hat nur 45mm Vorbau ergibt in L 503mm. Das ist aber alles imho nicht so relevant weil:
Weshalb fühlt sich dein Cube etwas zu gross an? Kann es sein weil es so hoch ist? 5cm mehr Sitzrohr, also 515mm, bei deiner Schrittlänge ist sehr sehr viel...mir wäre das viel zu hoch. Gleichzeitig ist das Cube recht kurz. Damit sitzt Du hoch und mehr über dem Lenker, auch durch den langen Vorbau...das fühlt sich dann an als würdest du über dem Rad sitzen, oben drauf. Damit kommt einem das evtl. zu groß vor.
Wenn es geht solltest Du das mal testen und ein L und XL probefahren, ich wette XL gefällt Dir besser...aber keine Garantie.
:daumen: würde ich auch tippen.
Der Vorbau am Cube dürfte sicherlich 7 oder 9° Steigung. Positiv gedreht verkürzt es das Bike.
Hi, I can read your English fluently, but writing is too exhausting, so I hope you can translate it for you. ;)
The manufacturers' size recommendations should generally be taken with caution. For example, I am 180cm with SL 85cm. I would recommend Ghost size M, I also tested it and it's too short.
So I took it in L.
Of course, these are all purely personal assessments and recommendations, but for me it looks like this ... does it look too big?
You are 5-6 cm taller than me and have a longer torso. How would you look if you sit on my L? The XL is 3cm larger in all directions, how about that?
About your cube: The cube probably has at least a 90mm stem, which results in a virtual reach of 515mm at 425mm reach. The Nirvana only has a 45mm stem which means 503mm in length. But this is all imho not so relevant because:
Why does your cube feel a little too big? Could it be because it's so high 5cm more seat tube, so 515mm, with your stride length is very, very much ... that would be much too high for me. At the same time, the cube is quite short. So you sit high and more over the handlebars, also due to the long stem ... that feels like you're sitting over the bike, on top of it. That might make it seem too big.
If you can, you should try it out and test drive an L and XL, I bet you like XL better ... but no guarantee.
Thanks for your input, I apreciate it. And, btw, pls write in Deutsch, google's autotranslate works pretty well for German :)
Right now, I ride with shorter stem on Cube (65mm, stock was 90mm) so tehnically, even with shorter stem on L size Nirvana (45mm), it would still be 1.2cm longer reach from what I'm riding now, and it would be, I think perfect.
Seeing your picture, with same stride length and 5cm shorter, it really fits you nicely and you are leaned down nicely. With my 5cm taller upper body, I would sit like I do on my Cube now, 1cm stretched, and I think it would be perfect for what I want to use Nirvana - light flow trails. Unfortunately I don't have a chance to try the bikes and see what size would fit me. I think I will go with L and if it feels too small, I'd exchange it for XL. I would preffer Nirvana to feel a bit more nimble than my Cube does on trails, I just don't want to feel like I am on a "baby bike" :)
Thanks to all of you! And again, I appologize for writing in english :)
Eine ganz wichtige Sache noch: wenn du einen Dropper einbauen willst, die original Sattelstütze hat 30mm Offset, 95% aller Dropper haben 0mm, damit machst du das Oberrohr also 30mm kürzer...nicht dass es dann zu kurz wird.
Wie machst du das mit dem Google Übersetzer? Wenn ich damit mein Deutsch in Englisch übersetze sieht es auch wie chinesisches Englisch 😏 gibts da eienen Trick...habs aber auch seit 3 Jahren nicht mehr genutzt...
Danke für das Angebot, wären 6 Stunden hin und zurück. Habe jetzt das Fahrrad in S bestellt und hoffe ich werde nicht enttäuscht 😊
Habe das Fahrrad gestern erhalten und direkt geschaut, dass ich alles auf mich einstelle. Passt soweit ganz gut, ich denke Größe M wäre für mich zu groß gewesen, im Vergleich zu meinem 26er vorher wirkt das Rad sehr groß.
Beim Sattel ist mir jetzt aufgefallen, dass ich für das passende Knielot den Sattel ganz vorne montiert haben muss (bis zum Stop). Das heißt doch, ich könnte theoretisch eine Stütze verbauen, die einen kleineren Offset hat oder? Wäre gut im Falle eines Dropper-Kaufs :)
Die Maße einstellen ist eine Sache, damit fahren gehört aber auch dazu. Du wirst also beim fahren merken ob du dich wohl fühlst und es passt. Wenn ja, wäre ein Dropper ohne Offset kein Problem.
Ja richtig. Was mir auf jeden Fall aufgefallen ist, dass die SX Schaltung nochmal eingestellt werden muss, die läuft noch nicht ganz perfekt, außerdem ungewohnt den Trigger nur mit dem Daumen zu bedienen. Gab es dazu nicht einen Link hier im Thema, wegen der Einstellung?
Hi Leute,
Ich habe vorgestern mein Nirvana Tour Essential bestellt und freue mich wie verrückt auf die erste Tour... Hab nun festgestellt, dass es keine Remote am Lenker für den Lockout gibt.
Kann man sowas gut nachrüsten? Ist ja eigentlich nur ein Hebel + Kabel...
Grüße
Hi Leute,
Grüße
Ich hab mal meine persönliche Meinung wieso der Lockout komplett überflüssig ist hier geschrieben
https://www.mtb-news.de/forum/t/mtb...m-bikekauf-siehe-seite-1.746523/post-16711319
Hi Leute,
Grüße
Du wirst ihn nicht benötigen.
Tatsächlich ist es allerdings auch etwas mehr Material als ein Hebel und Kabel. Gibt es auch nicht für jede Gabel.
Hmm, OK. Ich habe mal bei X-Fusion angefragt.
Danke für Eure Meinungen. Dann probiere ich es erstmal so aus
