aber auf den Prototype bin ich gespannt... hab mal ne Frage: weiß jemand ob die 4X in Willingen befahrbar ist?? weil Winterberg hat ja geschlossen (also die 4X) ... Danke!
bei denen mal das "Rennsystem" kennenlernen kann
Nichts genaues, nur paar Bilder von der Eurobike etc.
Dartmoor Bikes schrieb:Hornet 4X is the fusion between the stability of Dartmoor Hornet and the geometry of our so far Four-cross machine: Dartmoor Phantom. On the construction side it will have the same new arrivals as Hornet 2014 so you will be welcomed with a fully integrated, short headsets; new, custom designed and stiffer seat stays; strong 135x12mm through axle.
Hornet 4X gained its rapid geometry from his older brother, Phantom while staying in the lightweight category of 2.1kg. The 400mm chain stays will make it a very agile frame to sneak through the hard elbows of the opponents. The head angle of 67 degrees points in no other way than the finish line of the track and a 609mm effective top tube length as well as 340mm (13.5") seat tube size should suit the needs of the riders who shred them. For 2014 it will come out in only size and is compatible with 26" wheels. All the geometry settings were measured for a 100mm travel fork.
