mtb-trialer
Henrik
^kann mir jemand sagen was der reifen wiegt?
http://www.bike-components.de/catalog/product_info.php?cPath=245_100&products_id=4335
hmm ich versteh das voll nicht! ich hab ja schon nen minion in ner dh version.ChrisKing schrieb:der bei bike components muss die DH Version sein. Steht ja auch da, "DH".
Laut weightweenies wiegt z.b. n 2.35er High Roller in 42ST 1242g. Also wird der Minion da auch ungefähr so viel wiegen..
Kannst auch mal bei mountainbikes.net kucken. Die ham auch alle möglichen Maxxis. Oder bei bike-mailorder
planetary1 schrieb:The only Minion version you need to worry about is the 40a (that is the "Slow Reezay" or "SR" compound) You also have to get the DH 2.5 size because it is double ply. Yes it is somewhat heavy. The single ply 40a is amazing for grip and lighter but the sidewalls are too thin and you will pinch flat all of the time. Any other Maxxis compound, even the 42a "Super Tacky" is not worth it. The 40a SR compound is the best tire out there at the moment, even better than the Michelin. The Try All Sticky tire might be a good. I am ordering one tomorrow to replace my worn out Minion so we will see...
The 2.35 version is also available in dual ply, isn't it?
Minion DH R 2.35 60DW wire DPC SR/40a 1160g.
