die ultraleichten schläuche sind nu raus, allerdings wohl dauernd ausverkauft, und entsprechend teuer...
http://www.bikecorner24.de/eclipse-ultralight-schlauch-mtb-26-15225-56g-p-1400.html
bilder vom neuen Atomz Quark 26" ! ziemlich gestylte karre wie ich finde! und das Gewicht von 8.6-8.9kg ist auch nicht von schlechten eltern.
http://tribalzine.com/?Zoom-sur-le-Quark-II-26&lang=fr
müsste die carbon gabel sein, die hier ja schonmal gepostet wurde.viel interessanter finde ich die Gabel, woa?
I'm also testing a new revision of the spade prototype fork. The last one i had broke very quickly, likely due to the internally butted steerer. I worked with adam (bigman) on revising the dropout to distribute braking force more evenly across the fork, and the steerer is no longer butted. even with these changes, the fork is more than 20g lighter than the previous one. after cutting the steerer, my fork tips the scale at 692g. the new fork is also constructed with u6 alloy.
the new disc side dropout. the dropout thickness is reduced in non critical areas to save weight, and there is an extension to distribute the braking force to a larger area of the fork legs.
the steerer is now thicker, and no longer butted
non disc side dropout remains the same (as far as i know)
the fork is extremely wide. tire clearance definitely will not be an issue
because the fork is a prototype, they didn't bother with the finish. i actually prefer this look.
the new rockbar carbon. it is the same bar as the no war, but has a 3 month warranty, and is a lot cheaper.
some other new things worth mentioning :
the slate2 frame is now available in a new grey color. the newer batches are also lighter at 1468g.
here is the 20" 3d stem. the stem is the same as the try all 3d that benito is using on his sky
