Hallo Robin,
unsere Kettenspanner sind nun endlich lieferbar.
Der Spanner ist in Zwei Versionen lieferbar. Einmal für Singlespeed Naben und für 6-9 fach Naben.
Der Preis beträgt EUR 37,-
Gruss
Volker
74kingz High-End Bike Parts
http://www.echobike.com/
HS33 Alternative, wuerde ich genauso wie den hebel alleine nicht benutzen.
ausserdem das neue limey, bzw v.2.
http://www.trials-forum.co.uk/forum/index.php?showtopic=90116
Und nach der Beschreibung auf
Scheinbar im Alleingang.www.echobike.com schrieb:We believe the hydraulic rim brake has the best performance for rear wheel. So we always want to refit the current hydraulic rim brake. We have made brake pads, CNC clamps, booster, even the longer level blades. But the current hydraulic rim brake is die casting, the body is not very strong. And it's design for narrow XC rim, the clipper cylinder will hit rider's ankle when using wider rim. The shaft of the level blade keep loosing because it's thread on. So in year 2005, we decided to make a trials specific hydraulic rim brake by ourselves. It has a compact design, small size clipper cylinder. All aluminum parts are CNC from 6061 aluminum block. the stainless steel shaft of level blades is non thread design, wouldn't loose. German made rubber sealed and mineral brake fluid. The hydraulic plastic hose with fiber in, wouldn't break by bending.
Available as full system, or level set. The level blades are available in 6 colors. all small parts available separated.
www.echobike.com schrieb:To completed ECHO FFW drive system, we decided to make this trials specific design freewheel. It's made from CRMO steel, it has 6 pawls for 72 engagement points. Sealed ball bearing. Removable by a SHIMANO B.B. tool. The chain ring is 2mm closer to left side, for better chain line.
Magura hat ja scheinbar eh kein Interesse die Bremse entweder für Trial freizugeben oder explizit eine dafür zu bauen.
