Hi guys !
I've been lurking for months, and finally registered here to ask for your expertise in Torques.
I dismantled the rear triangle to clean and grease everything up, and noticed that the rear triangle is not aligned to the suspension pivot.
I attached some pictures I took today, you can see that there is a 2-4mm gap on each side.
To put everything back together I have to push the rear triangle sideways to align it with the pivot. Otherwise it doesn't fit...
Is it the same with your frame ?
Vielen Dank !
Ich kann ein bisschen Deutsch aber habe lange nicht mehr Deutsch geschrieben, und kenne auch keine fahrrad wörter ! Englisch ist für mich einfacher
Vielen Dank !
