FATBIKE - Spezifische Teile Zusammenstellung
28. Oktober 2012
8
Halle Saale
Rahmen:
Surly: http://surlybikes.com/
*Pugsley (auch Necromancer) (Stahl) (135off/135off)
*Moonlander (Stahl) (135off/135off)
Salsa http://www.salsacycles.com/
*Mukluk II (Alu) (135/170)
*Mukluk III (Alu) (135/170)
*Mukluk Ti (Titan) (135/170)
*Beargrease (Renn-Mukluk) (135/170)
Carver Bikes http://www.carverbikes.com/ (nicht zu verwechseln mit der Handelsmarke von Fahrrad XXL!!!)
*Titanium O'Beast (Titan) straight 2011 (135/170)
*Titanium O'Beast (Titan) curved 2012 (135/170)
*Trans-Fat (Titan) dual suspension fatty 2013 (135/170)
On One http://www.on-one.co.uk/
*Fatty (Alu) (135/170)
9:ZERO:7 http://fatbikes.com/
*135mm Sliding (Alu)
*170mm (Alu)
*170mm (Carbon)
*190mm
Fatback http://www.fatbackbikes.com/
*Alu/Stahl/Titan Rahmenausführung
*Corvus Carbon (135/170)
Nicolai Maschienenbau
http://nicolai.net/14-1-Home.html
*Argon Fat (135/170)
Sandman http://www.sandmanbikes.be/
*Hoggar (Titan)
*Gobi (Alu)
*Atacama (Alu)
*Outback Tandem (Alu)
Fat Sand Bike http://fatsandbike.com/
*Aluminium Rahmen
Jeff Johns Bicycles http://www.jonesbikes.com/
*Titan & Stahl Rahmen- & Gabel-Ausführung
Troy Bikes
*Mysteria (Alu)
Twenty 2 Cycles https://www.twenty2cycles.com/
*Fat/Snow "Bully" (Titan)
44 Bikes http://www.44bikes.com/
*Big Boy (Alu)
Six 1 Six / 616 Bicycle Fabrication http://616fab.com/
*Fat Frame (Alu oder Titan)
Reeb Cycles http://www.reebcycles.com/
*Fat Frame auf Anfrage
Borealisbikes http://www.borealisbikes.com
*Dream Fattie (135/190)
*Yampa
Trek http://www.trekbikes.com/de/de/
*Farley(135/170)
Specialized
http://www.specialized.com/
Fat Boy (135/190)
*Fat Boy Expert (135/190)
Felt
http://www.feltbicycles.com/
*Bosch Concept Bike
Norco http://www.norco.com/
*Bigfoot Aluminium(135/170)
Cannondale
http://www.cannondale.com/
*Cooker Maxi Aluminium (135/170)
Kona
http://www.konaworld.com/
*Wo(135/170)
Singular
http://www.singularcycles.com/
*Puffin (135/170)
119 Bikes http://fat-bike.com/?p=15139
*Full Suspension SIMUS & TIREWOLF
Motobecane http://www.bikesdirect.com/products/fat-bikes.htm
*Fantome FB4 (135/135)??? Werde aus der Beschreibung nicht schlau
Diamant / Nakamura (Norwegen) http://www.kjellsykkel.no/2013-fatbike/nakamura-bigbob
*Mammuth (135/135)
*BigBob (135/135)
_________________________________________________________
GABELN
Jones
*Jones Fork, Stahl, 135 mm
*Truss Fork, Stahl/Titan, 135 mm
9:ZERO:7
*Aluminum Fork, 135 mm
White Brothers
*Snowpack Fork, 135 mm
german:a
*force flame, 130 mm - Federgabel
Salsa
*Enabler Fork, 100 mm
Surly
*Moonlander Fork 135mm Non-Offset
*Surly Pugsley 100mm Fork
*Surly Pugsley 135mm Centered Fork
*Surly Pugsley 135mm Offset Fork
Sandman
*Fixed Fork
Maverick
*DUC32 - Federgabel
*SC32 - Federgabel
Fatback
*Aluminium Fork 135mm
*FF1 Fork Carbon 135mm 15mmQR
Reifen:
Half-Fat:
Surly:
*Knard 29"x3.00"
Nokian
*Gazzoldi 26"x3.00"
Point(Arrow, Duro)
*Bigfoot (Leopard) 26"x3.00"
3GGG
*Big Boa 26"x3.45" (sind aber schmaler als 3.00")
Kenda
*Flame 26x3.00" (sind breiter als 3.00")
Full-Fat:
Surly
*Endomorph 26"x3.8" (27tpi & 120tpi)
*Larry 26"x3.8" (27tpi & 120tpi)
*Nate 26"x3.8" (27tpi & 120tpi & 120tpi Ultralight)
*Black Floyd 26"x3.8" (27tpi & 120tpi)
*Knard 26"x3.8" (27tpi & 120tpi)
*Big Fat Larry 26"x4.5" (120tpi & 120tpi Ultralight)
*Lou 26"x4.8" (120tpi)
*Bud 26"x4.8" (120tpi)
45NRTH
*Dillinger 26"x4.0" (120tpi)
*Hüsker Dü 26"x4.0" (27tpi & 120tpi Ultralight)
*Escalator (180tpi)
Fat Sand Bike
*Tommi Sea FSB Skull 26"x4.00"
VEE RUBBER
*Mission 26"x4.0" (120tpi)
*Spider 26"x4.00"
Origin8
*Devist8or 26"x4.0" (27tpi & 120tpi & 120tpi Ultralight)
Fatback
*Sterling 26"x4.5"
Specialized
*Ground Control 26"x4.6"
On-One
*Floater 26"x4.0"
FELGEN:
Surly
*Large Marge 65mm (32H)
1150g (DH), 950g (XC)
*Rolling Darryl 82mm (32H)
1030g (solid) 850g (drilled)
*Rabit Hole 29"x 50m (32H)
*Clown Shoe 100mm (32H)
907:
*Flattop 100mm (32H)
1150g (solid), 950g (drilled)
*Flattop 80mm (32H)
980g (solid), 795g (drilled)
Vicious Cycles
*Graceful Fat Sheba 80mm (32H)
1310g
Robsson:
*Hohlkammer: 80mm & 100mm (36h & 32h) (in vielen Bunten Farben)
*Einfach: 80mm & 100mm (36h)
Nimbus
*Dominator, 26" x 42 mm, 36H, 800/850 g
*Dominator 2, 28" x 42 mm, 36H, 900 g
Kris Holm
*XC, 28" x 38 mm, 36H, ? g
*Freeride, 26" x 47 mm, 36H
*Freeride 29er, 28" x 47 mm, 36H, 780 g
Fatback
* UMA 70mm (32H)
* UMA 90mm (32H)
* UMA 80mm CARBON (32H)
Borealis
* Carbondale, 85mm, 590 g, 32H
Origin 8
* 80mm Rims 32H
Innenlager:
Vierkant:
*Phil Wood square JIS BB 100mm
Isis:
*FSA Platinum Pro DH
*Truvative GigaPipe Team DH
BMX:
*Profile Racing BMX cranks/BB set für 100mm
Howitzer:
*Truvativ Howitzer Team BB für 100mm
Aussenliegende Lager:
in Kombination mit:
*Surly Mr.Whirly
*The Hive 15G
*e.13 XC Bottom Bracket for Snowbike Cranks
Naben
135mm Frontnaben
Paul
*135mm Front Disc Whub
9:ZERO:7
*135mm Front Hub
Salsa
*Enabler Front Hub 135mm Black w/skewer
Surly
*New Disc 135mm QR Front Hub 32h
165mm
Hadley
*165mm hub
Sun
*Ringle 165mm hub
Sturmey Archer
*SX-RB3
170mm
9:ZERO:7
*170mm Hubset
Hope
*Pro Evo 2 170mm Fat Bike Hub Set
Six 1 Six Fabrication
*170mm Hub Set
Phil Wood
*170mm Rear Hub
Salsa
*Mukluk 2 Rear Hub 170mm Alloy Axle
*Mukluk 3 Rear Hub 170mm Steel Axle
Fatback
Vorderradnabe 135mm von Fatback, hergestellt bei Hadley (perfekt verarbeitet!)
Vorderradnabe 135mm von Fatback, Asienimport, wahrscheinlich by Formula?
Hinterradnabe 170mm von Fatback, hergestellt bei Hadley (perfekt verarbeitet!)
Hinterradnabe 170mm von Fatback, Asienimport, wahrscheinlich by Formula?
*FH1 135mm Front 15QR
*FH1 190mm Rear
kleine Ergänzung :)
Rahmen:
Jones: http://www.jonesbikes.com/
*Titanium/Steel Spaceframe
*Steel Diamond
GABELN
Jones
907
White Brothers
german:a
Salsa
Surly
Maverick
*DUC32
*SC32
FELGEN:
Nimbus
Kris Holm
INNENLAGER:
Ausenliegende Lager
Sollen wir auch noch Naben in 170 mm hinten und 135 vorne sammeln?
Vielleicht könnte man auch noch einfügen, dass es sich bei german:a und Maverick um Federgabeln handelt
ich wollt nur eine info dazu geben. mir ist nicht ganz klar, warum sehr viele beiträge hier sich immer nur darum drehen müssen, möglichst billig etwas zu bekommen.
weil ob jetzt ein rad 100 euro mehr oder weniger kostet, ist doch wohl egal ...
weil es als Student, der ich da noch war, ne Menge Holz ist... ich hab dafür einen Eigenbau Custom Cruiser verkaufen müssen...
Rechne doch mal selber zusammen:
Surly Pugsley Rahmen: 600€ (im Radladen! nicht online!)
Steuersatz Octane One: 35€
Innenlager Truvativ Team DH: 56€
Kurbel NC17: 30€ (NOS Schnäppchen)
Kettenblatt: 20€
Bremsen v+h Avid Elixir 5: 200€ (im Radladen! nicht online!)
Lenker Spank Tweet Tweet 70mm: 45€
Vorbau Funn Rippa: 30€
Spacer NC17: 9€
VR Nabe Quando TX SS: 50€
HR Nabe Alfine 8: 150€
Triggershifter Alfine 8: 39€
Bremscheibe Centerlock: 20€
Pedale NC17: 25€
Speichen Sapim: 45€
Felgen Robbson: 90€
Unterlegscheiben: 5€
Sattelstütze SARS/TUNE: 45€
Sattel Royal: 20€
Reifen Larry: 120€
Kettenspanner: 30€
Schläuche VeeRubber: 20€
Flaschenhalter: 10€
Griffe: 15€
Lenkerenden: 5€
Kette KMC: 15€
Ritzel Surly: 20€
Ritzel SRAM: 5€
das läppert sich alles ganz schön zusammen...1754,-€... ich hätte auch ein fertiges Rad für bekommen...aber meine Teile Auswahl sollte zu mir passen :D... und ein paar Euro an jeder Ecke mehr...und das Bike würde heute noch nicht rollen...
ich weiß schon, was du meinst.
und nach einigen individuellen radaufbauten weiß ich alle vorteile und nachteile. aber - ein gut zusammengestelltes rad (ht) kostet halt nunmal so um die 2000 € (+/-). und auch wenns nicht hierher gehört: das ewige gesudere um ein mtbike - am besten um 500 € - ist manchmal unerträglich ...
(ich mein jetzt nicht dich!)
ich hab mir vor ein paar wochen einen salsa rahmen gekauft. genauer: einen mukluk in schwarz. mit roter schrift. schaut echt lässig aus. hat 550 € gekostet. samt gabel (modell 2012)
ein paar sachen kann ich weiterverwenden (bremsen, steuersatz, lenker, schaltung, etc.). reifen, felgen, naben, sattelstütze, kurbel und innenlager brauch ich noch.
meine vorstellung:
reifen: 45nrth escalator
felgen: surly rolling darryl
sattelstütze: entweder thomson oder eine vario
innenlager: wenn geht chris king, sonst raceface
kurbel: raceface fatbike
naben: salsa rot eloxiert
bremsen avid elixir cr mit 185 vo/hi
schaltung: shimano xtr 9 fach
schalthebel: shimano xtr
umwerfer: shimano xt (wenn er passt), sonst sram x 9
vorbau: thomson
lenker: specialized riser
griffe: crank brothers
steuersatz: chris king
wenns soweit ist, kommen bilder ...
ps: wenn ich alle teile hab, gibts auch die gewichts und preisangaben ...
Ich denke auch, das hochpreisiges hier sehr wohl mit rein gehört...warum den auch nicht. Ist doch schließlich nur ne Katalogisierung der am Mark angebotenen Teile.
@alf2013 kannst du mal bitte sagen, aus was die Gabel nun genau ist? Stahl oder Alu? Was die Bilder angeht, die man so findet, schaut sie immer nach Stahl aus, was mit einem Alu Rahmen einfach nicht geht - in meinen Augen.
die gabel ist aus alu.
eine surly-gabel (für ein anderes bikeprojekt) ist schmäler, aber wiegt wesentlich mehr. auch die wandstärke ist um einiges dicker ... (eben stahl)
die oberfläche vom salsa-rahmen ist etwas rauher. optisch schaut es fast nach einer pulverbeschichtung aus. kann es nicht besser beschreiben. gefällt mir aber recht gut. und es war der vorletzte rahmen, den der importeur noch hatte. weil die neuen farben gefallen mir alle nicht ...
Hi. Hab mal ne Frage. Ich suche ne passende Gabel für den BFL. Problem, ich habe ein komplettes VR von jemanden abgekauft wo ein Nabendynamo drinn ist. Kann man die Salsa Gabel nutzen_ Die Surly Gabel ist ja erst ab März wieder verfügbar.
Oder hat hier zufällig einer eine rum liegen, die er nicht mehr brauch_ Benötigt wird also für Nabenbreite 100mm.
Gruss, Maik
Ja ist auch das was ich dazu im Netz lese. Habe nur diese Seite hier gefunden und da standen ja so Komponenten. Bei der Salsa Gabel stand 100 mm, deshalb dachte ich, das es eben für normale 100mm Breite.
Es gibt sowohl von Salsa als auch Surly Gabeln für 100mm Nabenbreite, allerdings muss man im Zweifelsfall Kompromisse eingehen. Wäre hilfreich, wenn du auch ein paar angaben machst: was ist "der BFL"? Welche Felgen/Reifenbreite willst du fahren?
Der Big Fat Larry ist aber 4,7" Zoll breit und passt nur in die Gabel des Moonlander. Kann es sein, dass es ein normaler Larry ist? Die Felge(nbreite) ist auch entscheidend, also obs ne Marge, Darryl, oder gar Clown Shoe ist.
Es gibt zwei Möglichkeiten: Nachdem es ein komplkettes Laufrad ist muss es ja schon mit passender Gabel funktioniert haben,... ooooder der Verkäufer hat das Rad gerade weil es nicht passt abgegeben.
