Trek Remedy 29 Series 2014
Remedy 7 29
 Trek Remedy 7 29 Specs:
Frame - Alpha Platinum Aluminum, ABP Convert, Full Floater, E2 tapered head tube, internal derailleur & dropper post routing, press fit BB,
ISCG 05 mount, magnesium EVO Link, Mino Link, down tube guard, G2 Geometry, 140mm travel
Front suspension - RockShox Revelation RL w/Solo Air, Motion Control DNA damper, lockout, rebound, E2 tapered steerer, 15mm Maxle Lite, custom G2 geometry w/51mm offset, 140mm travel
Rear suspension - Fox Evolution Series Float w/DRCV, CTD (climb-trail-descend) damper, rebound, tuned by Trek in California, 7.75Ã2.125â³
Wheels - Bontrager alloy, 15mm alloy axle front hub; Bontrager sealed cartridge bearing rear hub w/Bontrager Duster 32-hole Tubeless Ready rims
Tires - Bontrager XR3 Expert, aramid bead, 29Ã2.30â³
Shifters - Shimano Deore, 10 speed
Front derailleur - Shimano Deore, high direct mount
Rear derailleur - Shimano SLX Shadow Plus
Crank - Shimano M552, 42/32/24
Bottom bracket - press fit
Cassette - Shimano HG62 11-36, 10 speed
Saddle - Bontrager Evoke 2, chromoly rails
Seatpost - Bontrager Rhythm Elite, 31.6mm, zero offset
Handlebar - Bontrager Low Riser, 31.8mm, 5mm rise
Stem - Bontrager Rhythm Comp, 31.8mm, 7 degree
Grips - Bontrager Rhythm, dual lock-on
Headset - FSA NO.57SC, E2, semi-cartridge bearings
Brakeset - Shimano M596 hydraulic disc
MSRP $2699
Remedy 8 29
 Trek Remedy 8 29 Specs:
Front suspension - Fox Evolution Series 34 Float w/CTD (climb-trail-descend) damper, rebound, E2 tapered steerer, 15QR thru axle, custom G2 Geometry w/51mm offset, 140mm travel
Wheels - Bontrager sealed cartridge bearing, 15mm alloy axle front hub; 142Ã12 rear hub w/Bontrager Duster 28-hole Tubeless Ready rims
Shifters - Shimano SLX, 10 speed
Front derailleur - Shimano SLX, high direct mount
Rear derailleur - Shimano Deore XT Shadow Plus
Brakeset - Shimano SLX hydraulic disc
MSRP $3299
Remedy 9 29
 Trek Remedy 9 29 Specs:
Front Suspension - Fox Factory Series 34 Float w/CTD (climb-trail-descend) adjustable FIT damper, rebound, E2 tapered steerer, Kashima coating, 15QR thru axle, custom G2 Geometry w/51mm offset, 140mm travel
Rear Suspension - Fox Performance Series Float w/DRCV, CTD (climb-trail-descend) damper, rebound, tuned by Trek in California, 7.75Ã2.125â³
Wheels - Bontrager Rhythm Elite Tubeless Ready w/Stacked Lacing, Rapid Drive, 15mm front hub; 142Ã12 rear hub
Tires - Bontrager XR3 Team Issue Tubeless Ready, aramid bead, 29Ã2.30â³
Shifters - Shimano Deore XT, 10 speed
Front Derailleur - Shimano Deore XT, high direct mount
Rear Derailleur - Shimano Deore XT Shadow Plus
Crank - Shimano Deore XT, 38/24
Bottom Bracket - Press fit
Cassette - Shimano Deore XT 11-36, 10 speed
Seatpost - RockShox Reverb Stealth, 31.6mm, zero offset
Handlebar - Bontrager Race Lite Low Riser, 31.8mm, 5mm rise
Stem - Bontrager Rhythm Pro, 31.8mm, 7 degree
Headset - FSA NO.57E, E2, sealed bearings
Brakeset - Shimano Deore XT hydraulic disc
MSRP $4499
http://www.vitalmtb.com/photos/features/First-Look-All-New-Trek-Remedy-29-and-Fuel-EX-29,5633/First-Look-All-New-Trek-Remedy-9-29,55818/bturman,109
